lorawan nanogateway pytrack gps
Hello everyone,
I have a fipy connected to a pytrack board, I am using the setup as a lorawan nano gateway. The programming is such that it picks GPS location and builds the payload adding the location as part of the udp packetdef _make_node_packet(self, rx_data, rx_time, tmst, sf, bw, rssi, snr): lat, long = getloc() RX_PK["rxpk"][0]["time"] = "%d-%02d-%02dT%02d:%02d:%02d.%dZ" % (rx_time[0], rx_time[1], rx_time[2], rx_time[3], rx_time[4], rx_time[5], rx_time[6]) RX_PK["rxpk"][0]["tmst"] = tmst RX_PK["rxpk"][0]["freq"] = self._freq_to_float(self.frequency) RX_PK["rxpk"][0]["datr"] = self._sf_bw_to_dr(sf, bw) RX_PK["rxpk"][0]["rssi"] = rssi RX_PK["rxpk"][0]["lsnr"] = snr RX_PK["rxpk"][0]["lat"] = lat RX_PK["rxpk"][0]["long"] = long RX_PK["rxpk"][0]["data"] = ubinascii.b2a_base64(rx_data)[:-1] RX_PK["rxpk"][0]["size"] = len(rx_data) return ujson.dumps(RX_PK)this is the sample packet sent to the server
[ 597.437] Received packet: {"rxpk": [{"rfch": 0, "freq": 868.1, "long": 36.77718, "data": "QA0AABcARwcBD+JLPezpX6pRMFTl0A2O4d12u6SftNVgOEE/uRKh7rUm", "lsnr": 6.0, "codr": "4/5", "datr": "SF12BW125", "time": "2018-12-05T06:25:59.808526Z", "modu": "LORA", "size": 42, "lat": -1.29687, "tmst": 994609182, "stat": 1, "chan": 0, "rssi": -48}]}It works but occassionally I get this output on the console:
Guru Meditation Error: Core 1 panic'ed (LoadProhibited) . Exception was unhandled. Register dump: PC : 0x400fd268 PS : 0x00060e30 A0 : 0x800ddda4 A1 : 0x3ffdbc90 A2 : 0x00000001 A3 : 0x00000001 A4 : 0x00000000 A5 : 0x00000001 A6 : 0x00000000 A7 : 0x00060023 A8 : 0x800fc05a A9 : 0x3ffe70f0 A10 : 0x00000001 A11 : 0x00000001 A12 : 0x3f94fe00 A13 : 0x3f94fe00 A14 : 0x3ffe7260 A15 : 0x3ffe71c0 SAR : 0x00000020 EXCCAUSE: 0x0000001c EXCVADDR: 0x00000001 LBEG : 0x4009b414 LEND : 0x4009b41f LCOUNT : 0x00000000 Backtrace: 0x400fd268:0x3ffdbc90 0x400ddda1:0x3ffdbcb0 0x400dde0b:0x3ffdbcd0 0x400de2d1:0x3ffdbd00 0x40108a7e:0x3ffdbd20 0x400f4fbe:0x3ffdbd50 0x400f1945:0x3ffdbd80 0x400fcd33:0x3ffdbda0 0x400f5048:0x3ffdbe40 0x400f1945:0x3ffdbe80 0x400fcd33:0x3ffdbea0 0x400f5048:0x3ffdbf40 0x400f1945:0x3ffdbfc0 0x400f1972:0x3ffdbfe0 0x400de363:0x3ffdc000 0x400de634:0x3ffdc0a0 0x400dd345:0x3ffdc0c0i also get this log
[ 597.870] Downlink timestamp error!, t_us: 4292846312plus some very long core dump. What could be causing this issue?
Try using :
import gc ... gc.collect()the last line in some parts of the nanogateway code. Maybe is out of memory issue creating that error.
@rcolistete thank you for the pointer I have tried and no problems so far I'll give it a couple of days before sending it to the wild :)
