    LoPy - Raw Lora mode for connecting TTN
    loralorawanlora classnodelopy
    4 Posts 2 Posters 727 Views 3 Watching
      aniket_yeole
      I am trying to change the parameters of my LoRa node by configuring the node is raw mode i.e (LoRa(mode=LoRa.LORA)). But I am getting following error
      File "<stdin>", line 25, in <module>
      OSError: the requested operation is not possible
      Pycom MicroPython 1.18.1.r1 [v1.8.6-849-b0520f1] on 2018-08-29; LoPy4 with ESP32
      My sample code is as follows:
      import network
      from network import LoRa
      import struct
      import ubinascii
      import binascii
      lora = LoRa(mode=LoRa.LORA, frequency=868100000, power_mode=LoRa.ALWAYS_ON, tx_power=14, bandwidth=LoRa.BW_250KHZ, sf=7, preamble=8, coding_rate=LoRa.CODING_4_5, tx_iq=False, rx_iq=False)
      lora.init(mode=LoRa.LORA, frequency=868100000, power_mode=LoRa.ALWAYS_ON, tx_power=14, bandwidth=LoRa.BW_250KHZ, sf=7, preamble=8, coding_rate=LoRa.CODING_4_5, tx_iq=False, rx_iq=False)
      app_eui = ubinascii.unhexlify('xxxxxxxxxxxxxxxxxxxxxxx')
      app_key = ubinascii.unhexlify('xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx')
      while not lora.has_joined():
      time.sleep(2.5)
      print('Not yet joined...')
      if lora.has_joined():
      time.sleep(2.5)
      print ("Joined the network")
      s.setblocking(True)
      s.send("30")
      time.sleep(1.5)
      I would like to know if it is even possible to configure the node in raw Lora mode for connecting it to TTN network server?
      If yes where am I going wrong ?
      (Note: I am using a multichannel gateway)
      Please help
      Thanks and Regards,
      Aniket
        jcaron @aniket_yeole
        @aniket_yeole what exactly are you trying to achieve? Connecting to the network means using LoRaWAN, so why would you want/need to use raw LoRa? That would require you to re-implement the LoRaWAN stack yourself.
        By definition, if you use raw LoRa, you can’t use join as that’s part of LoRaWAN...
        Just use LoRaWAN mode and you should be all set...
          aniket_yeole @jcaron
          @jcaron
          I wanted to change the parameters like BW, Spreading Factor, Transmitting Power and to transmit on particular frequency manually. How to enforce the lopy to do it in LoRaWAN mode?
            @aniket_yeole you can change some of the parameters (including SF) using setsockopt. To change the frequency you’ll need to remove all channels and re-add channels with your chosen frequency. But beware, the network can change those settings via MAC commands.
