    micropython round
    upython on gpyrounding
    7 Posts 4 Posters 786 Views 4 Watching
    • K Offline
      kjm
      >>> round(691.69, 1)
      691.7
      makes sense
      >>> round(691.49, 1)
      691.5
      likewise
      >>> round(691.59, 1)
      691.5999
      how come?
      mfalkviddM robert-hhR 2 Replies Last reply Reply Quote 0
      • mfalkviddM Offline
        mfalkvidd @kjm
        @kjm 691.6 (and many other numbers) can not be representex correctly by a floating point number. Try entering the values into https://www.h-schmidt.net/FloatConverter/IEEE754.html and you'll see that there will be a large error.
        Longer explanation: http://www.phys.uconn.edu/~rozman/Courses/P2200_15F/downloads/floating-point-guide-2015-10-15.pdf#page3
        K 1 Reply Last reply Reply Quote 1
          robert-hh @kjm
          @kjm Decimal fractions cannot always be precisely expressed by a binary number. What you see is the attempt to get as close as possible to the value of 691.6. If a number is a binary fraction, like 591.5, it will be shown precisely, otherwise it is not guaranteed. If you use formatted print, the representation is rounded as expected. try print("%.1f" % round(691.59, 1))
          P.S.: if you just enter 591.6 at the REPL, it should also be echoed as 591.5999
            crumble
            And it is a good practice to compare values with a delta.
            as you can see, not all numbers can be represented. So instead of
            if val == 191.6:
              #do something
            you shall do something like
            delta = 0.1
            target = 691.6
            if  target-delta >= val && val <= target+delta:
              #do something
            So you take care that not all decimal values are represented. Which delta you shall choose depends on the precission you need and how your values a calculated. If in this case you multiply the error of 0.0001 by 10,000, you may have to use a huge delta of 1.
            Be careful with zero. On some architectures 0 does not equals -0. Lucky us, on the ESP32 it seems to be equal.
            • K Offline
              kjm
              • K Offline
                kjm @mfalkvidd
                @mfalkvidd I miss my raspberry pi
                >>> round(691.59, 1)
                691.6
                  robert-hh @kjm
                  @kjm This is a recurring discussion in Micropython. See also for instance:
                  https://forum.micropython.org/viewtopic.php?f=2&t=802
                  https://github.com/micropython/micropython/issues/3516
                  But still, the number which the raspi (C-Python) displays is not the number internally stored. However, using a 64 bit float representation, the error is way smaller.
                  Note also, that rounding was improved in the micrpython.org branch:
                  https://github.com/micropython/micropython/commit/b768cc6ca8ed6d7430b86dc7ccb9ee2391b3a251
                  For the esp8266 build, I get:
                  MicroPython v1.9.4-704-g62b4bebf-dirty on 2018-12-04; ESP module with ESP8266
                  >>> round(691.59, 1)
                  691.6
                  But not so for the ESP32 build. The loboris branch again delivers 691.6
                  But, so sum up: it is not the rounding, that "fails", it's the display of decimal fractions.
                  If you just enter 691.6, REPL will show 691.5999. Similar with other numbers, but not every number.
