    lte.isattached() is always false
    ltetelstra
    1 Posts 1 Posters 364 Views 4 Watching
    • M Offline
      misterlisty
      Anyone suggest why lte.isattached() is always false..we are using telstra nework if that helps. Has the latest dev firmware 1.20... using the fipy
      from network import LTE
      wait_time = 1
      def wait():
      print("Waiting {}".format(wait_time))
      time.sleep(wait_time)
      lte = LTE()
      print("Resetting ... ", end='')
      reply = lte.send_at_cmd('AT^RESET')
      print("DONE: {}".format(reply))
      wait()
      carrier = 'Telstra Mobile'
      def status():
      print("")
      print("Status")
      print(lte.send_at_cmd("ATI"))
      print(lte.send_at_cmd('AT!="showphy"'))
      print(lte.send_at_cmd('AT!="fsm"'))
      print("
      def do(command, sleep_time):
      print("Sending: {}.".format(command))
      response = lte.send_at_cmd(command)
      print("Response: {}".format(response))
      wait()
      return response
      def getLTE():
      if lte.isconnected(): return lte
      if not lte.isattached():
      print('attaching ', end=''); lte.attach()
      while not lte.isattached(): print('.', end=''); time.sleep(1)
      if not lte.isconnected():
      print('connnecting ', end=''); lte.connect()
      while not lte.isconnected(): print('.', end=''); time.sleep(1)
      return lte
      do('AT+CGDCONT=1,"IP","telstra.m2m"', 1)
      do('AT!="addscanfreq band=28 dl-earfcn=9410"', 1) # in place of: lte.attach(band=28)
      do('AT+CFUN=1', 1)
      getLTE()
      do('AT+COPS=?', 1)
      result = do('ATI', 1)
      r=requests.get('http://micropython.org/ks/test.html'); print(r.text)
      lte.disconnect()
