    T-Mobile NB-IoT in the Netherlands? [SOLVED]
    t-mobilenetherlandsnb-iotgpy
    22 Posts 6 Posters 1.4k Views 8 Watching
      Joop Susan
      Has anyone gotten T-Mobile NB-IoT in the Netherlands working on FiPy or GPy?
      I have updated my GPy to version 1.18.1.r7 and the LTE modem to version NB1-40343.
        Paul Thornton
        Hey.
        What issue are you having? Is it failing to attach, or attaching but failing to make any external connections?
          Joop Susan
          Hello @paul-thornton,
          It is failing to attach. Functions lte.imei() and lte.iccid() return sensible values. AT+CSQ returns 27,99.
          >>> import sqnsupgrade
          >>> sqnsupgrade.info()
          <<< Welcome to the SQN3330 firmware updater [1.2.1] >>>
          >>> GPy with firmware version 1.20.0.rc4
          UE6.0.0.0
          LR6.0.0.0-40343
          My test code:
          import os
          from network import LTE
          lte = None
          def get_LTE():
              global lte
              if lte == None:
                  lte = LTE()
              if lte.isconnected():
                  return True
              lte.attach(band=8, apn="cdp.iot.t-mobile.nl")
              attempts = 0
              while not lte.isattached():
                  time.sleep(5)
                  attempts = attempts + 1
                  print('Attaching...', attempts)
              print('LTE attach succeeded!')
              lte.connect()
              attempts = 0
              while not lte.isconnected():
                  time.sleep(5)
                  print('Connecting...', attempts)
              print('LTE connection succeeded!')
              return True
          def end_LTE():
              global lte
              if lte == None:
                  return
              print("Disonnecting LTE ... ")
              lte.disconnect()
              print("Detaching LTE ... ")
              lte.dettach()
              print("Shuttting down LTE...")
              lte.deinit()
              lte = None
          def test_LTE():
              os.uname()
              get_LTE()
              time.sleep(60)
              end_lte()
          if __name__ == "__main__":
              test_LTE()
          After more than an hour it is still not attached.
          The T-Mobile Netherlands IoT page only describes how to connect other platforms. (Link).
          What can I try next?
            Joop Susan
            Still never attaching...
            Added suggested commands 'AT+SQNCTM?', 'AT+SQNMONI=9', 'AT+CEREG?', 'AT+CFUN?' by @Xykon in threads 'Modem's radio showphy, all zeros, is bad?' and 'FiPy LTE not connecting after Upgrade Firmware'.
            This is my latest test code:
            import os
            def send_at_cmd_pretty(cmd, delay=1000):
                response = lte.send_at_cmd(cmd, delay=delay).split('\r\n')
                print('Sent to modem: \'{}\', delay {} ms'.format(cmd, delay))
                for line in response:
                    if line.strip() != '':
                        print(line)
            un = os.uname()
            print('Sysname:', un.sysname);
            print('Release:', un.release);
            print('Version:', un.version);
            print('Machine:', un.machine);
            lte = LTE()
            time.sleep(5)
            print ('Query LTE modem imei...', lte.imei()[:5] + '*' * 10)
            print ('Query SIM iccid...', lte.iccid()[:5] + '*' * 15)
            send_at_cmd_pretty('ATI1')
            send_at_cmd_pretty('AT!="showver"')
            time.sleep(5)
            send_at_cmd_pretty('AT+SQNCTM?')
            print('LTE attaching...')
            attempts = 0
                time.sleep(5)
                if attempts % 5 == 0:
                    send_at_cmd_pretty('AT+SQNMONI=9')
                    send_at_cmd_pretty('AT+CEREG?')
                    send_at_cmd_pretty('AT+CFUN?')
                    send_at_cmd_pretty('AT+CSQ')
                    send_at_cmd_pretty('AT!="showphy"')
                    send_at_cmd_pretty('AT!="fsm"')
            lte.connect()
            attempts = 0
                time.sleep(5)
            time.sleep(30)
            lte.disconnect()
            lte.dettach()
            lte.deinit()
            This is the output that it generates:
            Sysname: GPy
            Release: 1.20.0.rc4
            Version: v1.9.4-1444e48 on 2019-01-07
            Machine: GPy with ESP32
            Query LTE modem imei... 35434**********
            Query SIM iccid... 89882***************
            Sent to modem: 'ATI1', delay 1000 ms
            UE6.0.0.0
            LR6.0.0.0-40343
            OK
            Sent to modem: 'AT!="showver"', delay 1000 ms
            SYSTEM VERSION
              FIRMWARE VERSION
                Bootloader0  : 5.1.1.0 [33080]
                Bootloader1  : 6.0.0.0 [40343]
                Bootloader2* : 5.1.1.0 [38638]
                NV Info      : 1.1,0,0
                Software     : 6.0.0.0 [40343] by robot-soft at 2018-11-07 13:57:00
                UE           : 6.0.0.0
              COMPONENTS
                ZSP0         : 1.0.99-3171
                ZSP1         : 1.0.98-3170
            OK
            Sent to modem: 'AT+SQNCTM?', delay 1000 ms
            +SQNCTM: standard
            OK
            LTE attaching...
            Attaching... 1
            Attaching... 2
            Attaching... 3
            Attaching... 4
            Attaching... 5
            Sent to modem: 'AT+SQNMONI=9', delay 1000 ms
            ERROR
            Sent to modem: 'AT+CEREG?', delay 1000 ms
            +CEREG: 2,0
            OK
            Sent to modem: 'AT+CFUN?', delay 1000 ms
            +CFUN: 1
            OK
            Sent to modem: 'AT+CSQ', delay 1000 ms
            +CSQ: 99,99
            OK
            Sent to modem: 'AT!="showphy"', delay 1000 ms
            DL SYNCHRO STATISTICS
                Synchro state                         : OFF
                PPU SIB1 ACQ watchdog                 : 0
                Frequency Hypothesis RF  (Hz)         : 0
                RSRP (dBm)                            : -21474836.00
                RSRQ  (dB)                            : -15.21
                Channel estimation state (Cell-spec.) : LOW CINR
                Channel estimation state (UE-spec.)   : LOW CINR
                Channel estimation state (MBSFN)      : LOW CINR
                Channel estimation CINR               : 0.08
                Channel length                        : SHORT
              AGC
                AGC RX gain (dB)                      : 38.56
                RX PSD BO (dBFs)                      : -19.87
                RX PSD (dBm)                          : -77.16
                Noise level RS (dBm)                  : -76.63
                Digital gain (dB)                     : 3.14
                CINR RS (dB)                          : -3.17
              NARROWBANDS
                Last DL NB                            : Central
                Last UL NB                            : 0
              AFC
                Frequency offset RF  (Hz)             : 2061
                Frequency offset BB  (Hz)             : 0
              PBCH
                MIB received quantity                 : 0
                MIB timeout quantity                  : 0
            OK
            Sent to modem: 'AT!="fsm"', delay 1000 ms
            SYSTEM FSM
                |            FSM           |        STATE       |
                | RRC TOP FSM              |INITIAL             |
                | RRC SEARCH FSM           |INITIAL             |
                | RRC ACTIVE FSM           |NULL                |
                | PMM PLMN FSM             |PARKING             |
                | EMM MAIN FSM             |NULL                |
                | EMM AUTH FSM             |NULL                |
                | EMM CONN FSM             |NULL                |
                | EMM TAU FSM              |NULL                |
                | EMM TEST FSM             |NULL                |
                | ESM BEARER FSM           |BEARER_NULL         |
                | SMS MT FSM               |IDLE                |
                | SMS MO FSM               |IDLE                |
                | LPP FSM                  |IDLE                |
                | HP MAIN FSM              |IDLE                |
                | HP USIM FSM              |READY               |
                | HP SMS MO FSM            |IDLE                |
                | HP SMS MT FSM            |IDLE                |
                | HP CAT FSM               |IDLE                |
            OK
            Attaching... 6
            Attaching... 7
            Attaching... 8
            Attaching... 9
            Attaching... 10
            +SQNMONI: Cc: Nc: RSRP:-1 CINR:-1 RSRQ:-1 TAC:11811 Id:226 EARFCN:6290 PWR:-1 PAGING:256
            OK
            +CEREG: 2,0
            OK
            +CFUN: 1
            OK
            +CSQ: 27,99
            OK
                Synchro state                         : DRX_SLEEP
                RSRP (dBm)                            : -76.21
                RSRQ  (dB)                            : -11.07
                Channel estimation state (Cell-spec.) : HIGH CINR
                Channel estimation CINR               : 10.64
              AGC
                AGC RX gain (dB)                      : 44.69
                RX PSD BO (dBFs)                      : -27.27
                RX PSD (dBm)                          : -82.46
                Noise level RS (dBm)                  : -88.05
                Digital gain (dB)                     : 1.18
                CINR RS (dB)                          : 11.84
              NARROWBANDS
                Last UL NB                            : 0
              AFC
                Frequency offset RF  (Hz)             : -467
              PBCH
            OK
            SYSTEM FSM
                |            FSM           |        STATE       |
                | RRC TOP FSM              |CAMPED              |
                | RRC SEARCH FSM           |CAMPED_ANY          |
                | RRC ACTIVE FSM           |IDLE                |
                | PMM PLMN FSM             |ANY_CAMPED          |
                | EMM TAU FSM              |NULL                |
                | SMS MT FSM               |IDLE                |
                | SMS MO FSM               |IDLE                |
                | LPP FSM                  |IDLE                |
                | HP MAIN FSM              |IDLE                |
                | HP CAT FSM               |IDLE                |
            OK
            Attaching... 11
            Attaching... 12
            Attaching... 13
            Attaching... 14
            Does the new output make sense to anyone and does anyone have suggestions what to try next?
              Joop Susan
              OK. So my GPy's hardware was to blame. (Link)
              Since I also have a more recent FiPy I upgraded that one to NB1 40343.
              Success! I can read the 'Hello World!' message on the T-Mobile Netherlands dashboard.
              If this code does not attach for you, check that the CAPS show that your band is supported. My GPy was missing band 8 and I have requested an RMA...
              Testing code:
              import os
              import usocket
                          print(line)
              # Print module details
              un = os.uname()
              # Initialize LTE object
              lte = LTE()
              time.sleep(5)
              # Pre attaching debugging
              print('Query LTE modem imei...', lte.imei()[:5] + '*' * 10)
              print('Query SIM iccid...', lte.iccid()[:5] + '*' * 15)
              send_at_cmd_pretty('AT!="RRC:setDbgPerm full"')
              send_at_cmd_pretty('AT!="RRC:showcaps"')
              time.sleep(5)
              # Attach LTE
              attempts = 0
                  time.sleep(5)
                  if attempts % 15 == 0:
              # Debug attached state
              send_at_cmd_pretty('AT+CGPADDR')
              send_at_cmd_pretty('AT+PING="172.27.131.100"', delay=5000)
              # Connect LTE
              lte.connect()
              attempts = 0
                  time.sleep(5)
              # Test DNS
              try:
                  usocket.dnsserver(0, '8.8.8.8')
                  usocket.dnsserver(1, '1.1.1.1')
                  usocket.dnsserver()
                  print(usocket.getaddrinfo('www.google.com', 80)[0][-1])
              except Exception:
                  print('DNS over NB-IoT failed...')
              # Send message to dashboard
              s = usocket.socket(usocket.AF_INET, usocket.SOCK_DGRAM)
              s.setsockopt(usocket.SOL_SOCKET, usocket.SO_REUSEADDR, 1)
              # s.settimeout(5)
              # s.setblocking(False)
              s.sendto(bytearray('Hello World!'), ('172.27.131.100', 15683))
              s.close()
              # Shutdown LTE
              lte.disconnect()
              lte.dettach()
              lte.deinit()
              Output:
              Sysname: FiPy
              Release: 1.20.0.rc7
              Version: v1.9.4-2833cf5 on 2019-02-08
              Machine: FiPy with ESP32
              UE6.0.0.0
              LR6.0.0.0-40343
              OK
              SYSTEM VERSION
                FIRMWARE VERSION
                  Bootloader0  : 5.1.1.0 [39529]
                  Bootloader1* : 6.0.0.0 [40343]
                  Bootloader2  : NA
                  NV Info      : 1.1,0,0
                  UE           : 6.0.0.0
                COMPONENTS
                  ZSP0         : 1.0.99-3171
                  ZSP1         : 1.0.98-3170
              OK
              Sent to modem: 'AT!="RRC:setDbgPerm full"', delay 1000 ms
              OK
              Sent to modem: 'AT!="RRC:showcaps"', delay 1000 ms
              == CAPS config =============================
                .Lock UE on SRV band    : false
                .MFBI support           : true
                .TM8 TDD support        : false
              == CAPS ====================================
                . access stratum: R13
                . catM          : 1
                . nb-IoT        : 1
              -- EUTRA bands --
                . supported     : 28/20/13/12/8/5/4/3
                . board         : 3/4/5/8/12/13/20/28
                . admin         :
                . pending admin :
              -- EUTRA carriers --
                . admin         :
                . pending admin :
              OK
              +SQNCTM: standard
              OK
              LTE attaching...
              Attaching... 1
              Attaching... 2
              +CEREG: 2,5,"04F5","00710C67",9
              OK
              +SQNMONI: 20416 Cc:204 Nc:16 RSRP:-78.30 CINR:5.60 RSRQ:-12.00 TAC:1269 Id:287 EARFCN:3747 PWR:-58.52 PAGING:1024
              OK
              +CSQ: 27,99
              OK
                  Synchro state                         : CELL_ACQUIRED
                  RSRP (dBm)                            : -79.52
                  RSRQ  (dB)                            : -12.22
                  Channel estimation CINR               : 3.51
                AGC
                  AGC RX gain (dB)                      : 42.49
                  RX PSD BO (dBFs)                      : -21.15
                  RX PSD (dBm)                          : -81.08
                  Noise level RS (dBm)                  : -83.83
                  Digital gain (dB)                     : 1.85
                  CINR RS (dB)                          : 4.31
                NARROWBANDS
                  Last UL NB                            : 0
                AFC
                  Frequency offset RF  (Hz)             : -737
                PBCH
              OK
              SYSTEM FSM
                  |            FSM           |        STATE       |
                  | RRC TOP FSM              |CONNECTED           |
                  | RRC SEARCH FSM           |CAMPED              |
                  | RRC ACTIVE FSM           |CONNECTED           |
                  | PMM PLMN FSM             |NORM_CAMPED         |
                  | EMM MAIN FSM             |REGISTERED          |
                  | EMM AUTH FSM             |KASME_DEFINED       |
                  | EMM CONN FSM             |EMM_CONNECTED       |
                  | EMM TAU FSM              |NULL                |
                  | ESM BEARER FSM           |BEARER_ACTIVE       |
                  | SMS MT FSM               |IDLE                |
                  | SMS MO FSM               |IDLE                |
                  | LPP FSM                  |IDLE                |
                  | HP MAIN FSM              |IDLE                |
                  | HP CAT FSM               |IDLE                |
              OK
              Sent to modem: 'AT+CGPADDR', delay 1000 ms
              +CGPADDR: 1,"10.0.1.100"
              OK
              Sent to modem: 'AT+PING="172.27.131.100"', delay 5000 ms
              +PING: 1,172.27.131.100,360,253
              Detaching LTE ...
              Pycom MicroPython 1.20.0.rc7 [v1.9.4-2833cf5] on 2019-02-08; FiPy with ESP32
              N 1 Reply Last reply Reply Quote 3
              • N Offline
                nadvorvo @Joop Susan
                Hi @Joop-Susan, thank you for your testing code.
                I have used it for my NB-IoT tests.
                1. In my system there is no existing AT command AT+PING.
                  Also I did not find it modem manual:
                  https://docs.pycom.io/gitbook/assets/Monarch-LR5110-ATCmdRefMan-rev6_noConfidential.pdf
                2. In my system lte.send_at_cmd function require only one parameter
                >>> lte.send_at_cmd('ATI1',1000)
                TypeError: extra positional arguments given
                So finally I have changed function send_at_cmd_pretty like this:
                    response = lte.send_at_cmd(cmd).split('\r\n')
                            print(line)
                Could somebody explain points 1), 2), please?
                Thank you in advance for your assistance.
                Regards, Vojtech
                Sysname: GPy
                Release: 1.20.2.r3
                Version: v1.11-d945d33ee on 2020-03-08
                UE6.0.0.0
                LR6.0.0.0-41019
                OK
                SYSTEM VERSION
                  FIRMWARE VERSION
                    Bootloader0  : 5.1.1.0 [41065]
                    Bootloader1* : 6.0.0.0 [41019]
                    Bootloader2  : 5.1.1.0 [41065]
                    NV Info      : 1.1,0,0
                    Software     : 6.0.0.0 [41019] by robot-soft at 2018-12-13 21:41:15
                    UE           : 6.0.0.0
                  COMPONENTS
                    ZSP0         : 1.0.99-3171
                    ZSP1         : 1.0.98-3170
                OK
                OK
                  . catM          : 1
                  . nb-IoT        : 1
                -- EUTRA bands --
                  . supported     : 66/28/26/25/20/19/18/17/14/13/12/8/5/4/3/2/1
                  . board         : 1/2/3/4/5/8/12/13/14/17/18/19/20/25/26/28/66
                  . admin         :
                  . pending admin :
                  . admin         :
                  . pending admin :
                OK
                +SQNCTM: standard
                OK
                LTE attaching...
                Attaching... 1
                Attaching... 2
                Attaching... 3
                Attaching... 4
                Attaching... 5
                +CEREG: 2,5,"B7B6","0003E421",9
                OK
                +SQNMONI: Vodafone@ Cc:230 Nc:03 RSRP:-92.80 CINR:-0.40 RSRQ:-14.10 TAC:47030 Id:76 EARFCN:6447 PWR:-70.92 PAGING:256
                OK
                +CSQ: 21,99
                OK
                    RSRP (dBm)                            : -92.98
                    RSRQ  (dB)                            : -14.28
                    Channel estimation CINR               : -0.75
                  AGC
                    AGC RX gain (dB)                      : 50.54
                    RX PSD BO (dBFs)                      : -22.57
                    RX PSD (dBm)                          : -93.56
                    Noise level RS (dBm)                  : -92.07
                    Digital gain (dB)                     : 4.86
                    CINR RS (dB)                          : -0.91
                  NARROWBANDS
                    Last UL NB                            : 0
                  AFC
                    Frequency offset RF  (Hz)             : -538
                  PBCH
                OK
                SYSTEM FSM
                    |            FSM           |        STATE       |
                    | EMM CONN FSM             |AS_ESTABLISHED      |
                    | EMM TAU FSM              |NULL                |
                    | SMS MT FSM               |IDLE                |
                    | SMS MO FSM               |IDLE                |
                    | LPP FSM                  |IDLE                |
                    | HP MAIN FSM              |IDLE                |
                    | HP CAT FSM               |IDLE                |
                OK
                +CGPADDR: 1,"10.0.1.197"
                OK
                  File "<string>", line 64, in <module>
                OSError: LTE modem version not read```
                  For
                  1. AT commands are sort of universal. The manual you mention only describes AT commands specific to the Sequans modem. If you check this forum thread: https://forum.pycom.io/topic/6202/method-to-take-control-of-cell-modem/29 there are more 'undocumented' commands.
                  2. There was a change in lte.send_at_cmd() not requiring the delay argument anymore in a recent firmware, as that was solved in a different way.
                  Edit: The AT+PING command is described in the Sequans AT commands manual! (see link)
                  Best,
                  • N Offline
                    nadvorvo @Gijs
                    Hi @Gijs,
                    Thank you for your reply.
                    Could you suggest how to use AT+PING command on GPy?
                    So far I understand @Joop-Susan using his testing code also with Sequans modem (FiPy)?
                    Regards, Vojtech
                      Hi
                      Usage is like this:
                      lte.send_at_cmd('AT+PING="8.8.8.8"') where 8.8.8.8 can be any IP address. This works on any device with an LTE modem. Be aware that the quotes are not interchangable, the AT command interpreter expects the double ".
                      N 1 Reply Last reply Reply Quote 1
                      • N Offline
                        nadvorvo @Gijs
                        Hi @Gijs ,
                        I am using GPy + modem with NB-IoT fw NB1-41019.
                        Could you help, why AT+PING does not work, please?
                        I really appreciate the support you’ve given me.
                        Regards, Vojtech
                        Complete test output:
                        Sysname: GPy
                        Release: 1.20.2.r3
                        UE6.0.0.0
                        LR6.0.0.0-41019
                        OK
                        SYSTEM VERSION
                          FIRMWARE VERSION
                            NV Info      : 1.1,0,0
                            UE           : 6.0.0.0
                          COMPONENTS
                            ZSP0         : 1.0.99-3171
                            ZSP1         : 1.0.98-3170
                        OK
                        OK
                          . catM          : 1
                          . nb-IoT        : 1
                        -- EUTRA bands --
                          . admin         :
                          . pending admin :
                          . admin         :
                          . pending admin :
                        OK
                        +SQNCTM: standard
                        OK
                        LTE attaching...
                        Attaching... 1
                        Attaching... 2
                        Attaching... 3
                        Attaching... 4
                        Attaching... 5
                        OK
                        OK
                        +CSQ: 21,99
                        OK
                            RSRP (dBm)                            : -92.98
                            RSRQ  (dB)                            : -14.28
                          AGC
                          NARROWBANDS
                            Last UL NB                            : 0
                          AFC
                          PBCH
                        OK
                        SYSTEM FSM
                            |            FSM           |        STATE       |
                            | EMM TAU FSM              |NULL                |
                            | SMS MT FSM               |IDLE                |
                            | SMS MO FSM               |IDLE                |
                            | LPP FSM                  |IDLE                |
                            | HP MAIN FSM              |IDLE                |
                            | HP CAT FSM               |IDLE                |
                        OK
                        OK
                          That is a really odd error to get after the AT+PING command. The
                          Can only be caused by the lte.connect() command and has nothing to do with the lte.send_at_cmd(...)
                          I tried what you are doing on my Fipy with NB1-41019 firmware, and it does not do this.. Can you perhaps get the firmware 1.20.2.r1 and try again? There might be some differences in 1.20.2.r3 that I do not know about..
                          • N Offline
                            nadvorvo @Gijs
                            Hi @Gijs,
                            I really appreciate the support you’ve given me. Sorry for some delays (I was out of office several days).
                            I am now trying to downgrade to 1.20.2.r1 ... as you know I have some troubles:
                            https://forum.pycom.io/topic/1735/failed-to-connect-to-esp32-invalid-head-of-packet-x08/6
                            Today I have made some test with NB-IoT.
                            I have noticed weak signal:
                            >>> lte.send_at_cmd('AT+CSQ')
                            '\r+CSQ: 18,99\r\rOK\r'
                            rssi=18 ... -77dBm
                            Below -70 dBm: Signal is too weak, subject to external interference
                            Today even I could not attach (usually it takes few seconds and I get lte.isattached() = true). Could it be hint why AT+PING command get error?
                            >>> lte = LTE()
                            >>> lte.attach(band=20, apn="nb.zoocontrol")
                            >>> lte.isattached()
                            False
                            Regards, Vojtech
                            • N Offline
                              nadvorvo @nadvorvo
                              Hi @Gijs,
                              finally I have to downgrade to 1.20.2.r1
                              Then I have executed testing code. Still having problems with attaching (pls see my last post regarding rssi).
                              Regards, Vojtech
                              >>> exec(open('./lte_test.py').read())
                              Sysname: GPy
                              Release: 1.20.2.r1
                              Version: v1.11-a5aa0b8 on 2020-09-09
                              UE6.0.0.0
                              LR6.0.0.0-41019
                              OK
                              SYSTEM VERSION
                                FIRMWARE VERSION
                                  NV Info      : 1.1,0,0
                                  UE           : 6.0.0.0
                                COMPONENTS
                                  ZSP0         : 1.0.99-3171
                                  ZSP1         : 1.0.98-3170
                              OK
                              OK
                                . catM          : 1
                                . nb-IoT        : 1
                              -- EUTRA bands --
                                . admin         :
                                . pending admin :
                                . admin         :
                                . pending admin :
                              OK
                              +SQNCTM: standard
                              OK
                              LTE attaching...
                              Attaching... 1
                              Attaching... 2
                              Attaching... 3
                              Attaching... 4
                              Attaching... 5
                              Attaching... 6
                              Attaching... 7
                              Attaching... 8
                              Attaching... 9
                              Attaching... 10
                              Attaching... 11
                              Attaching... 12
                              Attaching... 13
                              Attaching... 14
                              Attaching... 15
                                robert-hh @nadvorvo
                                @nadvorvo I'm just using lte.attach() here with a T-Mobile NB-IoT card. attaching usually takes 12 seconds, but sometimes much longer. The response to AT+CSQ is 25,99. I'm using MicroPython 1.20.2.rc11, and the latest modem firmware 41019, and the same bootloader.
                                Ping to 172.27.131.100 fails in a proper manner with error, ping to e.g. 217.160.86.40 or 8.8.8.8 works.
                                Maybe you have a problem with the antenna or reception. Can you move close to a window?
                                • N Offline
                                  nadvorvo @robert-hh
                                  Hi @Gijs,
                                  Today I have sold problem with lte.attach(). It was necessary to add before (select network operator):
                                  lte.send_at_cmd('AT+COPS=1,2,"23003"')
                                  Ping not working even after FW downgrade to 1.20.2.r1.
                                  Regards, Vojtech
                                  Sysname: GPy
                                  Release: 1.20.2.r1
                                  UE6.0.0.0
                                  LR6.0.0.0-41019
                                  OK
                                  SYSTEM VERSION
                                    FIRMWARE VERSION
                                      NV Info      : 1.1,0,0
                                      UE           : 6.0.0.0
                                    COMPONENTS
                                      ZSP0         : 1.0.99-3171
                                      ZSP1         : 1.0.98-3170
                                  OK
                                  OK
                                    . catM          : 1
                                    . nb-IoT        : 1
                                  -- EUTRA bands --
                                    . admin         :
                                    . pending admin :
                                    . admin         :
                                    . pending admin :
                                  OK
                                  +SQNCTM: standard
                                  OK
                                  LTE attaching...
                                  Attaching... 1
                                  Attaching... 2
                                  Attaching... 3
                                  Attaching... 4
                                  Attaching... 5
                                  OK
                                  +SQNMONI: Vodafone@ Cc:230 Nc:03 RSRP:-93.10 CINR:-0.90 RSRQ:-14.20 TAC:47030 Id:76 EARFCN:6447 PWR:-71.12 PAGING:256
                                  OK
                                  +CSQ: 20,99
                                  OK
                                      PPU SIB1 ACQ watchdog                 : 1
                                      RSRP (dBm)                            : -93.51
                                      RSRQ  (dB)                            : -14.33
                                      Channel estimation CINR               : 0.05
                                    AGC
                                      AGC RX gain (dB)                      : 55.79
                                      RX PSD BO (dBFs)                      : -20.32
                                      RX PSD (dBm)                          : -93.14
                                      Noise level RS (dBm)                  : -92.36
                                      Digital gain (dB)                     : 1.44
                                      CINR RS (dB)                          : -1.15
                                    NARROWBANDS
                                      Last UL NB                            : 0
                                    AFC
                                      Frequency offset RF  (Hz)             : -524
                                    PBCH
                                  OK
                                  SYSTEM FSM
                                      |            FSM           |        STATE       |
                                      | EMM TAU FSM              |NULL                |
                                      | SMS MT FSM               |IDLE                |
                                      | SMS MO FSM               |IDLE                |
                                      | LPP FSM                  |IDLE                |
                                      | HP MAIN FSM              |IDLE                |
                                      | HP CAT FSM               |IDLE                |
                                  OK
                                  OK
                                    @nadvorvo said in T-Mobile NB-IoT in the Netherlands? [SOLVED]:
                                    So we are back here again If im correct. I tested the AT+PING again om my devices and that seems to work fine (still!). I have asked @xykon to take a look as well, so we can figure this out!
                                      Sorry for the long delay, I have since looked at your code again, and the AT+PING does not return anything for you, try the following:lte = LTE(debug=True) which will give you more insight into the sent AT commands by the lte module.
                                      The error is with the lte.connect() which has a version check, that receives a non-applicable response from the modem.
                                      Next, I figured out that the AT+PING has no specified timeout. This will interfere with the next AT command called (ATI1) and cause the modem version not read error, as the AT+PING has still information in the UART buffer. You can resolve the issue by setting a timeout on the AT+PING command as such:
                                      send_at_cmd_pretty('AT+PING="172.27.131.100",1,32')
                                      With 1 = the amount of messages, and 32 as the timeout in ms (I believe)
                                      That should resolve the error
                                      Best,
                                      • N Offline
                                        nadvorvo @Gijs
                                        Hi @Gijs,
                                        I have updated my testing code as suggested (also it was necessary add 5 sec sleep (there were interfere with lte.connect() comand):
                                        lte = LTE()
                                        print('LTE ping test')
                                        send_at_cmd_pretty('AT+PING="10.1.0.1",1,32', delay=5000)
                                        time.sleep(5)
                                        # Connect LTE
                                        print('LTE connect command:')
                                        lte.connect()
                                        I got this output:
                                        LTE ping test
                                        [AT] 939910 AT+PING="10.1.0.1",1,32
                                        [AT-OK] +9509
                                        Sent to modem: 'AT+PING="10.1.0.1",1,32', delay 5000 ms
                                        Could you comment, please [AT] 939910, [AT-OK] +9509 I do not know meaning.
                                        Regards, Vojtech
                                          Im not sure exactly what you are trying to achieve with the PING (and who you are trying to ping), but a ping to 8.8.8.8 for me gives a response acknowledgement. It seems 10.1.0.1 is in the personal IP range, which might not be directly accessible from the lte service.
                                          • N Offline
                                            nadvorvo @Gijs
                                            Hi @Gijs,
                                            10.1.0.1 is the address of the NB-IoT backend server ... UDP communication is working there.
                                            I have tried 8.8.8.8 (result is same, My APN network is opened to internet by default, only to backend server)
                                            LTE ping test
                                            [AT] 80166 AT+PING="8.8.8.8",1,32
                                            [AT-OK] +9506
                                            Sent to modem: 'AT+PING="8.8.8.8",1,32', delay 5000 ms
                                            Regards, Vojtech
                                            • 1
                                            • 2
                                            • 2 / 2
