    Pybytes release 21.1.2019
    pybytesrelease
    3 Posts 2 Posters 1.0k Views 2 Watching
      jirkakrepl
      Today we're going to release the new version of Pybytes + Pybytes firmware.
      Please update the firmware of all of your devices Otherwise, Pybytes won't work properly.
      We simplified the creation of signals. Now there's no need to define data type (There's no Data type field in the new signal form). A data type is now sent automatically by the device. Supported Python dataTypes are String, Float, Int, Array, and Tupple.
      We simplified the function for sending data from Python send_virtual_pin_value. You can replace it with send_signal function. We will still support send_virtual_pin_value function for some time.
      # old API:
      # permanent - legacy parameter, don't have any effect
      # signal number shown in Pybytes. 0 - 255 signals
      # data - variable you're sending
      pybytes.send_virtual_pin_value(permanent, signalNumber, data)
      #e.g.:
      pybytes.send_virtual_pin_value(False, 1, 'hello')
      # new API:
      pybytes.send_signal(signalNumber, data)
      #e.g:
      pybytes.send_signal(1, 42)
      pybytes.send_signal(1, 3.14)
      pybytes.send_signal(1, 'hello')
      pybytes.send_signal(1, (42, 3.14))
      software developer @ Pycom
      • N Offline
        nervencid
        About the parameter 'signalName', i think is relevant to clarify that this parameter corresponds whit the tag "Signal" and not "Name"
          jirkakrepl
          Good point, I'll update the docs.
