    PyBytes Firmware OTA update failed?
    lopy
    3 Posts 2 Posters 392 Views 2 Watching
      dnear1
      I logged into Pybytes to look at my LoPy4 Signals compared to the data shown in TTN. It's connected to a WIFI network but also pushing LoRa data in US915 databand. I noticed that the signals values were all screwed up. Previously last night, everything looked good. Looking at the data values, I discovered that Signals had somehow changed from big to little-endian so a value I believe to be 3(?) was now displayed as 285,212,672 (Hex 1100 0000) all 5 signals I had were affected by this.
      I tried to go in and look at the code, but the unit said "Offline". Odd, because Signals was being updated on 5 minute intervals, as was TTN. I watched several 5 minute update intervals succeed.
      On the Settings page, I noticed it showed a Firmware Update was available. I had 1.18.1r10 loaded and it reported that 1.18.2 was available. I attempted the update. It said "updating firnware" for about 3-4 minutes, then finally reported back it failed. TTN stopped receiving frames as did Signals after this. It's 50 miles away so I probably won't get to it until maybe late tonight or tomorrow.
      I wasn't using any deep sleep routines, just time.sleep(300) at the end of my loop as I was still figuring out code issues.
      I attached my code in case someone suggests that it could be the cause of FOTA failure..
      # main.py -- put your code here!
      from network import LoRa
      import ubinascii
      import struct
      import os
      import math
      import abpkeys
      import ustruct
      from machine import UART, I2C, Pin
      #from machine import I2C, Pin #added for si7021 rh sensor
      from si7021 import SI7021 #added for si7021 rh sensor
      uart = UART(1, 9600)                         # init with given baudrate
      uart.init(9600, bits=8, parity=None, stop=1) # init with given parameters
      #initialize i2c to link to rh sensor
      i2c = I2C(0, pins=("P9","P10"))
      i2c.init(I2C.MASTER, baudrate=9600)
      sensor = SI7021(i2c=i2c)
      # Initialise LoRa in LORAWAN mode.
      # Asia = LoRa.AS923
      # Australia = LoRa.AU915
      # Europe = LoRa.EU868
      # United States = LoRa.US915
      lora = LoRa(mode=LoRa.LORAWAN, region=LoRa.US915)
      #my keys are stored in abpkeys.py then linked here so I have the same source running
      #on multiple devices
      dev_addr=abpkeys.dev_addr
      nwk_swkey=abpkeys.nwk_swkey
      app_swkey=abpkeys.app_swkey
      #dev_addr = struct.unpack(">l", ubinascii.unhexlify('xxxxxxxx'))[0]
      #nwk_swkey = ubinascii.unhexlify('xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx')
      #app_swkey = ubinascii.unhexlify('xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx')
      for i in range(0, 71):
          lora.remove_channel(i)
      print('Removed default channels')
          # Set US ISM 915 channel plan for TTN US
      lora.add_channel(0, frequency=903900000, dr_min=0, dr_max=3)
      lora.add_channel(1, frequency=904100000, dr_min=0, dr_max=3)
      lora.add_channel(2, frequency=904300000, dr_min=0, dr_max=3)
      lora.add_channel(3, frequency=904500000, dr_min=0, dr_max=3)
      lora.add_channel(4, frequency=904700000, dr_min=0, dr_max=3)
      lora.add_channel(5, frequency=904900000, dr_min=0, dr_max=3)
      lora.add_channel(6, frequency=905100000, dr_min=0, dr_max=3)
      lora.add_channel(7, frequency=905300000, dr_min=0, dr_max=3)
      #channel	8:	903900000	hz	min_dr	0	max_dr	3
      #channel	9:	904100000	hz	min_dr	0	max_dr	3
      #channel	10:	904300000	hz	min_dr	0	max_dr	3
      #channel	11:	904500000	hz	min_dr	0	max_dr	3
      #channel	12:	904700000	hz	min_dr	0	max_dr	3
      #channel	13:	904900000	hz	min_dr	0	max_dr	3
      #channel	14:	905100000	hz	min_dr	0	max_dr	3
      #channel	15:	905300000	hz	min_dr	0	max_dr	3
      print('US channels set')
      print('restoring LoRa NVRAM')
      lora.nvram_restore()
      print('Joining LoRa via ABP')
      # join a network using ABP (Activation By Personalization)
      # create a LoRa socket
      # set the LoRaWAN data rate
      s.setsockopt(socket.SOL_LORA, socket.SO_DR, 3)
      #Let's check whether the si7021 is attached and enable further code if it responds
      print('check si7021 serial')
      si7021presence=True
      temperature=-255
      print(i2c.scan())
      temperature=int(sensor.temperature())
      relativehumid=int(sensor.humidity())
      dewpoint=int(sensor.dew_point())
      print('Temp',temperature)
      print('RH%',relativehumid)
      print('Dewpoint',dewpoint)
      try:
          print('temperature = ',temperature)
      except NameError as msg:
          print(msg)
          si7021presence=False
      if( temperature !=-255):
          print('temperature reported = ',temperature)
      print('si7021 presence = ',si7021presence)
      #The first 5 seconds of dust data always seems irregular, so let's delay and clear the buffer
      data = uart.readall()
      time.sleep(10)
      data= uart.readall()
      time.sleep(1)# then give it another second for the next good byte to come in.
      while (1):
          readytosend=False
          print('polling Dust Sensor')
          data = uart.readall()# get everythitng from the serial buffer
          if data is not None:#make sure it'st not an empty buffer
              bytestream=data.split(b'BM')[1][0:31]# HPMA sends 32 byte packets that start with \x42\x4D ('BM')
              if len(bytestream)==30:#check tthat we actually got 30 bytes (excluding the data we split out)
                  if bytestream[0:2]==b'\x00\x1c':#HPMA packet is always 28 data bytes(excluding start header and checksum)
                      checksum=143#since split command removed the \x42\x4D, add them back to get correct checksum
                      validated=0
                      for i in range(0,28):
                          checksum+=bytestream[i]#cycle thru the data values and add them up
                      validated=int(bytestream[28])*256+int(bytestream[29])#read checksum bytes from packet and make them a 2-byte integer
                      if checksum==validated:# both values should match, else we have a corrupt packet
                          pm25=int(bytestream[4])*256+int(bytestream[5])#these two bytes represent the particulate detected that's 2.5um large
                          pm10=int(bytestream[6])*256+int(bytestream[7])#these two bytes represent the particulate detected that's 10um large
                          print('pm2.5 = ',pm25)
                          print('pm10 = ',pm10)
                          readytosend=True
                          print('checksum failed')
                      print('invalid packet length')
                  print('incomplete packet')
          if(si7021presence==True):
              print(i2c.scan())
              print('poll temp')
              print('poll RH')
              print('poll Dew')
          if readytosend==True:
              # make the socket blocking
              # (waits for the data to be sent and for the 2 receive windows to expire)
              s.setblocking(True)
              print("Sending data!")
              # send some data
              # s.send(bytes([0x01, 0x02, 0x03]))
              #if(si7021presence==True):
              tempstruct=((ustruct.pack('>H',temperature)))
              rhstruct=((ustruct.pack('>H',relativehumid)))
              dewstruct=((ustruct.pack('>H',dewpoint)))
              s.send(bytes([bytestream[4], bytestream[5], bytestream[6],bytestream[7],tempstruct[0],tempstruct[1],rhstruct[0],rhstruct[1],dewstruct[0],dewstruct[1]]))#,relativehumid,dewpoint]))
              #else:
              #    s.send(bytes([bytestream[4], bytestream[5], bytestream[6],bytestream[7]]))
              pybytes.send_virtual_pin_value(False, 0, (bytestream[4]<<8)+bytestream[5])
              pybytes.send_virtual_pin_value(False, 1, (bytestream[6]<<8)+bytestream[7])
              pybytes.send_virtual_pin_value(False, 2, temperature)
              pybytes.send_virtual_pin_value(False, 3, relativehumid)
              pybytes.send_virtual_pin_value(False, 4, dewpoint)
              #pybytes.send_virtual_pin_value(False,2,100)
              #time.sleep(10)
          print('saving LoRa NVRAM')
          lora.nvram_save()
          # (because if there's no data received it will block forever...)
          s.setblocking(False)
          print("receiving data!")
          # get any data received (if any...)
          data = s.recv(64)
          print(data)
          print("Go to sleep 5 minutes!")
          time.sleep(300)```
        dnear1
        I was able to get it back online by unplugging and replugging power. The firmware update didn't take. I tried it a second time, and that took. But now have a bunch of corrupted signals data..
          Paul Thornton
          Hey.
          Whilst not super convinient as its 50 miles from you. If you can reclaim it and flash https://forum.pycom.io/topic/4185/new-pybytes-firmware-1-18-1-r9-experimental-lte-support manually
          Is should solve the issue with corrupted / weird data from Lora.
