    Problems with Pymakr in VS code
    pymakrotherbug
    9 Posts 3 Posters 1.3k Views 4 Watching
    • N Offline
      nervencid
      Hello:
      I'm new and i tried to install Pymakr in atom and worked fine for now, but when i tried to install it on VSCODE, it didn't worked, the device is not connecting and it crashes.
      I got in the console this:
      Connecting on 192.168.4.1...
      Connection error: Error: Login timed out
      Where can i report this bug?
      Thank you
      • R Offline
        Ralph
        Hi @nervencid, can you provide any info on how it crashes? The 'Connection error: Error: Login timed out' is not a crash, it's that you are not connected to the boards wifi. If you want to connect over usb, I'd recommend enabling auto_connect in the general settings.
        • N Offline
          nervencid @Ralph
          @ralph Thank you for your answer:
          The autoconnect via USB is enabled, and i am connecting via USB it works fine on atom, but it is not connecting on VScode
          • R Offline
            Ralph @nervencid
            @nervencid Did you set auto_connect in the global settings? This setting is not allowed in the project settings, so it's ignored. Which would result in the message you're seeing.
            • W Offline
              washcycle
              This is my project pymakr.conf in vscode
                  "address": "COM6",
                  "username": "micro",
                  "password": "python",
                  "open_on_start": true,
                  "safe_boot_on_upload": true,
                  "sync_folder": "wipy"
              If you are using USB you are going to want to fill in the COM portion. I haven't used the atom IDE yet, not sure if it is smarter.
              • N Offline
                nervencid @Ralph
                @ralph Hello and thank you for the answer:
                How can i find the configurations for VS CodeĀ”
                Thank you
                • R Offline
                  Ralph @nervencid
                  @nervencid On the bottom there's a button called 'all commands' which opens a list. In the list click 'global settings'. There you can change the 'auto_connect' setting.
                  • N Offline
                    nervencid @Ralph
                    @ralph Hello and thank you for the answer, but the autoconnect is already in false, this is te configuration settings on VS Code:
                    	"address": "192.168.4.1",
                    	"sync_folder": "",
                    	"safe_boot_on_upload": false,
                    	"sync_file_types": "py,txt,log,json,xml,html,js,css,mpy",
                    	"ctrl_c_on_connect": false,
                    	"sync_all_file_types": false,
                    	"auto_connect": false,
                    	"py_ignore": [],
                    	"fast_upload": false
                    • R Offline
                      Ralph @nervencid
                      @nervencid With autoconnect to false, it indeed tries to connect to the address 192.168.4.1, so the output you posted is as expected. To connect you can either:
                      • connect to the devices wifi and klik connect again, or:
                      • change the auto_connect setting to true, or:
                      • set the address setting to the correct comport (you can find it using the 'list serialports' command)
                      With your input, this post could be even better šŸ’—
