    Pyscan datasheet is completely wrong
    pyscanspecsbug
    7 Posts 2 Posters 845 Views 2 Watching
      theshade
      Hello Pycom team,
      Just to notify that the pyscan pdf spec datasheet is just rubish
      if you go to the product page here:
      https://docs.pycom.io/datasheets/boards/pyscan.html
      and follow the link to the pdf:
      https://docs.pycom.io/.gitbook/assets/pyscan-specsheet.pdf
      you will find that none of the information including features, pictures, and mechanical dimensions (which is what I was trying to figure out) are anywhere related to the product but are just copy pasted from other datasheets...
      Cheers,
      T 1 Reply Last reply Reply Quote 4
        theshade @theshade
        Dimensions of the pyscan are actualy 40.25 x 57.00mm x 8.00 for those interested
          Paul Thornton
          Hello.
          Thanks, All the pinouts and spec sheets are going through an upgrade at the moment and will be fixed ASAP.
          Paul
            theshade @Paul Thornton
            @paul-thornton Thank you for that...
            Specifically I need to make my own intermediate PCB to be able to access the IO connector.
            Since it seems they are not on a grid would it be possible to have the coordinates of the connectors addedd to the specs sheets too?
            Of course I can probably guesstimate them but it's already difficult enough to insert them when they are perfectly aligned... so..
            Thank you!
            P 1 Reply Last reply Reply Quote 1
              Paul Thornton @theshade
              @theshade Seems like a logical thing to include. Ill see what I can do :)
              T 2 Replies Last reply Reply Quote 1
                Hello @paul-thornton
                Any update on the spec sheets or a hint on when "ASAP" could materialise?
                  Thank you @paul-thornton,
                  I just saw the addition to the web page with the mechanicals. I'll start drawing my board ;)
