    Web service
    otherenhancement
    3 Posts 3 Posters 445 Views 3 Watching
    • R Offline
      rohan123
      Which protocol is used to call a Web service?
      1 Reply Last reply Reply Quote -2
        Paul Thornton
        Most will run over http/https. but the payload format can change. from things like XML for soap. to Json/Xml for Rest some more modern ones may even be using protocol buffers or similar to encode payloads.
        Was there a specific webservice did you have in mind?
        • M Offline
          matthew4355
          a web service protocol stack is a protocol stack that is used to define,locate implement, and make web services interact with each other .
