    LOPY BLE Peripheral
    lopybleperipheral
    4 Posts 2 Posters 541 Views 2 Watching
    • M Offline
      mitchlau
      Hi i am beginner of LOPY
      I am trying to send pysense data to i phone from BLE
      As a result i am trying to {lopy as Peripheral -------(send data)------->i phone (central)}
      My question is
      1. Is there any Peripheral example to follow??
      2. I have import the library on the code however there is no file Bluetooth or network (Not sure where to find the library if i need to upload with Pymakr )
      3. why the code below result as 9999999999999??
      I use the code below
      import ubinascii
      from network import Bluetooth
      from time import sleep
      bt = Bluetooth()
      bt.init()
      bt.set_advertisement(name="lopy", manufacturer_data="lopy_v1")
      if bt.isscanning():
          bt.stop_scan()
      bt.start_scan(-1)
      while bt.isscanning():
          adv = bt.get_adv()
          if adv:
              print(adv)
      RESULT::
      mode:DIO, clock div:1
      load:0x3fff8028,len:8
      load:0x3fff8030,len:1728
      load:0x4009fa00,len:0
      load:0x4009fa00,len:14612
      entry 0x400a059c
      9
      9
      9
      9
      9
      9
      9
      9
      • M Offline
        mitchlau @mitchlau
        @mitchlau
        I get it pair with IOS however i dont know how to sent data over,
        Is anyone can give me an example on this
        import binascii
        from machine import Timer
        bluetooth = Bluetooth()
        bluetooth.set_advertisement(name='LoPy', service_uuid=b'1234567890123456')
        def conn_cb (bt_o):
            events = bt_o.events()   # this method returns the flags and clears the internal registry
            if events & Bluetooth.CLIENT_CONNECTED:
                print("Client connected")
                    print("data send")
                    bluetooth.set_advertisement(name='LoPy',manufacturer_data="lopy_v1")
                    time.sleep(2.050)
                print("Client disconnected")
        bluetooth.advertise(True)
          johand
          For BLE pairing is not needed.
          Look at this example: https://docs.pycom.io/firmwareapi/pycom/network/bluetooth/gattscharacteristic.html
          To send data, use:
          chr2.value(MyData)
          Johan
          M 1 Reply Last reply Reply Quote 1
          • M Offline
            mitchlau @johand
            @johand
            Thanks for the answer this work prefect
