    Hand soldering OEM modules
    oemreference boardsoldering
    8 Posts 6 Posters 503 Views 6 Watching
    • philwilkinsonP Offline
      philwilkinson
      Has anyone managed to successfully hand solder the OEM modules onto the reference boards?
      Lots of solder. Higher great settings. Patience.
      Nothing seems to work!
      T X 2 Replies Last reply Reply Quote 0
      • E Offline
        Eric Waai
        All you need is flux, a good soldering iron with good tip, experience and skills.
        for an experienced solderer this is done in a minute
        E 1 Reply Last reply Reply Quote 1
        • E Offline
          Eric73 @Eric Waai
          @eric-waai I agree, the only annoying pin is GND everey other pin must be solder with 330-350°C iron setting and SMD soldering wire, for GND pins set your soldering iron to 420°C and don't stay in contact more than 4 secondes to weld this pins then wait 1 minutes before retry if it not work.
            thinginnovations @philwilkinson
            @philwilkinson Having a supply of desoldering wick will help too, just use it after soldering and a large soldering iron tip. It will remove the surplus solder leaving neat joints.
            Andrew
              Paul Thornton
              As other's mentioned it's doable in a home lab fairly easily. Patience. (and flux) is the key.
                philwilkinson
                Ok, thanks all for the advice.
                I have been soldering for years and have never come across a board so hard to solder, it just will not take.
                It looks like I need to have a really hot iron setting.
                  I made about 10 boards with OEM modules that were reflowed in a simple oven very successfully, however there were a couple that were hand soldered successfully. They are doable.
                  • X Offline
                    Xykon administrators @philwilkinson
                    @philwilkinson said in Hand soldering OEM modules:
                    Yes I've done this many times. My secret is lots of flux, drag soldering and cleaning up with solder wick and more flux. Most problems come from using too much solder creating shorts underneath the pads or too little solder and not making a solid connection.
                    Christian Ehlers
