    No PyCom board found on USB
    6 Posts 3 Posters 1.2k Views 3 Watching
    • I Offline
      idlab
      Hello. I am new to all of this. I have followed instructions on how to install the driver and I have the device in my Device Manager (on Win7) listed under Ports as Expansion3 (COM4).
      When I try to connect to my board (pymakr in VSC), Autoconnect reports: "No PyCom board found on USB" yet when I run List Serial Ports I get:
      Found 2 serialports
      COM1 ((Standard port types)) (copied to clipboard)
      COM4 (Pycom Ltd)
      I have entered COM4 into address setting of pymakr.json, both global and project settings, but when I run Connect command, absolutely nothing happens. Not even a character of output in the Terminal.
      Does anyone have an idea of what I am doing wrong? Or what issues could be causing me this problem? Are there any additional steps I should make or any additional info I should provide?
      If I use PuTTY I can see that the thing is working as I get expected outputs.
      UPDATE:
      I have found the solution. I installed Atom and wanted to try there, but as soon as I entered settings I saw there was a comprehensive explanation for each setting, which says for Autoconnect: "Ignores any 'device address' setting and automatically connects to the top item in the serialport list"
      I have no idea how I should have known that as Connect command seemingly doesn't work if autoconnect is on. By Setting autoconnect to false, I was immediately able to connect in VSC and now everything seems to be fine.
        sarthak04
        Hey! Make sure you have NodeJS installed in your system too.
        • I Offline
          idlab @sarthak04
          @sarthak04 NodeJS is installed. Unless there is a specific version I need, this shouldn't be a problem.
            crumble @idlab
            @idlab
            please browse the forum. There exist a problem with the latest VisualStudio and the plugin.
            • I Offline
              idlab @crumble
              @crumble I have tried that first. It's hard to know what to search for if you don't know what the problem is.
                crumble @idlab
                @idlab said in No PyCom board found on USB:
                I am using Atom, so I cannot remember the solution or the title f the thread.
