FiPy upload failed
@justin No. Just trying to use UART1 does not damage the device.
@robert-hh Thanks. Could you then give me some hints on how I can make it work again? It was working for a long time but stopped uploading successfully since Saturday afternoon.
@justin You could try to start over by re-installing the firmware. When doing so, check th option for erasing the flash.
@robert-hh OK. Will try it tomorrow.
Just a curious question, is the firmware only for pysense/pytrack/expansion board? Or is there also firmware for FiPy/LoPy? I had this feeling when I was reading the information in the link of https://docs.pycom.io/pytrackpysense/installation/firmware.html
but not sure if I understand it correctly. -
@justin I was talking about the FiPy firmware. The expansion and sensor board have a separate firmware. Before reloading the FiPy, you could try to connect it using a pure terminal emulator like Putty (windows) or screen (OS X and Linux). Using that it is easier to tell the state of the FiPy. It avoids the potential trouble caused by pymakr.
Hello Robert, I tried to find out how to update the FiPy firmware and couldn't find the link. Could you kindly point one for me?
@robert-hh said in FiPy upload failed:Before reloading the FiPy, you could try to connect it using a pure terminal emulator like Putty (windows) or screen (OS X and Linux). Using that it is easier to tell the state of the FiPy. It avoids the potential trouble caused by pymakr.
In addition, is there a link on how to use putty to detect the state of the FiPy? Many thanks.
@justin if you get a REPL prompt in Putty and can enter commands, then the FiPy interface is OK. You have to disable flow control in the Putty serial interface settings. Try something like Ctrl-D, which should reboot the device. Ctrl-B should show the firmware revision. Or enter just any Python statement, like:
print("Hello World") -
@robert-hh hello Robert, I tried following your instruction. However, I was not able to type in the Putty window. This is how the putty window looks like.
@justin This is what I got when I opened Atom.
@justin In Putty, what happens after connection, when you push the reset button on the LoPy?
@robert-hh Please see the screenprint below. I was still not able to type.
@justin That looks like a physically sane device. It indicates the pybytes firmware. I do not know if that is what you wanted. If not, use the pycom updater to install the regular firmware.
@robert-hh That's weird. I was not able to upload using Atom. I am sure the pysense is ok as I tested it with another fipy which can perform upload normally.
@justin Atom is not the right tool for firmware update of the Fipy. You have to use the Pycom Updater: https://pycom.io/wp-content/uploads/2018/08/pycom_firmware_update_1.15.1 (1).exe.zip
@robert-hh Many thanks Robert. I have just done the firmware update for the FiPy and it is working normally now. I was confused in the beginning about the firmware for the Pysense and firmware for the FiPy. Many thanks for the patient explanation.
