GPy only shows band 13 supported
I'm trying to debug some issues where currently I am only able to connect to Verizon, and I don't even see other carriers listed in AT+COPS=? or AT+SQNMONI=9. I used to have a similar problem, but I was only able to connect to AT&T (though I did see Verizon listed).
In my troubleshooting, I ran AT!="showcaps" and on my GPy modules I see:
== CAPS config ============================= .Lock UE on SRV band : false .MFBI support : true .TM8 TDD support : false ============================================ == CAPS ==================================== . access stratum: R13 . catM : 1 . nb-IoT : 0 -- EUTRA bands -- . supported : 13 . board : 3/4/12/13/20/28 . admin : 13 . pending admin : -- EUTRA carriers -- . admin : . pending admin : ============================================On my older FiPy I see the output I would expect:
== CAPS config ============================= .Lock UE on SRV band : false .MFBI support : true .TM8 TDD support : false ============================================ == CAPS ==================================== . access stratum: R13 . catM : 1 . nb-IoT : 0 -- EUTRA bands -- . supported : 28/20/13/12/4/3 . board : 3/4/12/13/20/28 . admin : . pending admin : -- EUTRA carriers -- . admin : . pending admin : ============================================Does this mean I am only able to scan and connect using band 13 on the GPy? I have tried AT!="addScanBand band=2", but I still only see band 13 in the supported list.
I have the same issue. Did you manage to fix it?
Im having the same issue my self now, did you happen to figure out what the issue is?
