Documentation: pycom module 'machine'
 Just trying to understand the reset conditions for the machine and noticed that the docs are incomplete in relation to reset causes.
 When I runprint(machine.reset_cause())I am returned an interger value. The list at Reset Causes does not have reset listed against their correspoding integer values AND there is no explanation of the the 'methods'; e.g. ismachine.HARD_RESETcorrespond to bothmachine.reset()and abutton push?Thank you for your time
 @goldfishalpha You're right! Sorry for the confusion and good catch (I'll edit my previous post so as not to confuse future readers)
 @Colateral Thank you for your response. I am just thinking along the lines of logging reset reasons for my device.
 e.g. If I get a WDT reset at a certain time, check and save the reason on restart of system. Would be handy for analysing software/system stability.
 However, I have just noticed that a reset button press returns0on amachine.reset_cause().
 Will keep testing as I go along.
 @alexpul Thank you. It appears as if counting starts from 0though.
 To confirm, I spotted that one can runhelp(machine)to get a list..
 PWRON_RESET -- 0
 HARD_RESET -- 1
 WDT_RESET -- 2
 DEEPSLEEP_RESET -- 3
 SOFT_RESET -- 4
 BROWN_OUT_RESET -- 5
 PWRON_WAKE -- 0
 PIN_WAKE -- 1
 RTC_WAKE -- 2
 ULP_WAKE -- 3
 machine.HARD_RESET never happens: nor at push button(POWER RESET) and never on machine.reset() (that actually is tided to WDT_RESET) When this cause is happening?
 If you do machine.reset_cause()then the numbers correspond to the reset causes list
 0 - machine.PWRON_RESET
 1 - machine.HARD_RESET
 2 - machine.WDT_RESET
 3 - machine.DEEPSLEEP_RESET
 4 - machine.SOFT_RESET
 5 - machine.BROWN_OUT_RESETIf you do machine.wake_reason()then the numbers correspond to the wake reasons list
 0 - machine.PWRON_WAKE
 1 - machine.PIN_WAKE
 2 - machine.RTC_WAKE
 3 - machine.ULP_WAKE
