    Simple HTTP server
    http servermakefile
    3 Posts 2 Posters 391 Views 2 Watching
    • K Offline
      kjm
      I repurposed some generic micropython HTTP server code to run on the gpy
      import machine; from machine import Pin
      pins = [machine.Pin(i, machine.Pin.IN) for i in ('P23', 'P22', 'P21')]
      print (pins)
      html = """<!DOCTYPE html>
      <html>
          <head> <title>ESP8266 Pins</title> </head>
          <body> <h1>ESP8266 Pins</h1>
              <table border="1"> <tr><th>Pin</th><th>Value</th></tr> %s </table>
          </body>
      </html>
      addr = socket.getaddrinfo('0.0.0.0', 80)[0][-1]
      s = socket.socket()
      s.bind(addr)
      s.listen(1)
      print('listening on', addr)
          cl, addr = s.accept()
          print('client connected from', addr)
          cl_file = cl.makefile('rwb', 0)
              line = cl_file.readline()
              if not line or line == b'\r\n':
                  break
          rows = ['<tr><td>%s</td><td>%d</td></tr>' % (str(p), p.value()) for p in pins]
          response = html % '\n'.join(rows)
          cl.send(response)
          cl.close()
      It's supposed to show the status of the pins in a table but when I run it & try to login I get
      [Pin('P23', mode=Pin.IN, pull=None, alt=-1), Pin('P22', mode=Pin.IN, pull=None, alt=-1), Pin('P21', mode=Pin.IN, pull=None, alt=-1)]
      listening on ('0.0.0.0', 80)
      client connected from ('192.168.4.2', 58649)
        File "<stdin>", line 26, in <module>
      ValueError: invalid argument(s) value
      I can't find any docs on makefile so I was wondering if anyone can tell me what the problem is with
      • E Offline
        Eric73
        According to documentation (https://docs.pycom.io/firmwareapi/micropython/usocket.html) makefile seem have only one argument and not two. Logically i don't know any system where when you have write acces you haven't read access, so i propose you to try
        cl_file = cl.makefile('wb')
        Please note that's "import usocket" and not "import socket" as in your code with pycom library, if you use a different lib have a look at your provider's library documentation
        • K Offline
          kjm
          Spot on with the cl.makefile('wb') Eric, although I can't tell how you figured that out from that doc page. No matter it works now! If I change 'import socket' to 'import usocket as socket' it runs the same so the pycom library must have both?
