    multiple interrupt calls when sending with LoRa
    lorainterruptdebounclorawan
    2 Posts 1 Posters 379 Views 1 Watching
      loth4in
      Hi! I'm creating a tipping bucket rain gauge that should save every tip to the local flash memory and in the end send it as a payload through LoRaWAN. So far (without LoRa), everything worked fine. I'm using software debouncing and have no duplicates over long periods (hours) with 20 s tipping interval on our test device.
      However, now I added the LoRa code and on average get about 6 duplicates per 15 minutes. Each with approx. 3 s delay whatever time I use for debouncing - the sensor calls for 460 ms, so I tested a couple of different setups. Can anybody tell me where this might be coming from?
      main:
      # OTAA authentication parameters
      app_eui = ubinascii.unhexlify('app_eui')
      app_key = ubinascii.unhexlify('app_key')
      # join network using OTAA (Over the Air Activation)
      # create a LoRa socket
      Side note on main: I save the lora state after the first succesfull join and reload it on deepsleep wakeup
      raingage:
      # init pins
      self.gage = Pin(pin_in, mode=Pin.IN, pull=Pin.PULL_DOWN)
      self.wifi_pressed = Pin(pin_wifi, mode=Pin.IN, pull=Pin.PULL_DOWN)
      # init wake up interrupt
      machine.pin_deepsleep_wakeup(pins=[self.gage, self.wifi_pressed], mode=machine.WAKEUP_ANY_HIGH, enable_pull=True)
      # init interrupt action for rain gage
      self.gage.callback(trigger=Pin.IRQ_RISING, handler=self.drip)
      # handler for drip interrupt
      def drip(self, arg):
      	# debouncing
              # drip interval for 300 year rainstorm
      	if utime.ticks_diff(self.debounce_timer, utime.ticks_ms()) > 2500:
      		# get time of drip
      		drip_time = utime.time()
      		# init debounce_timer
      		self.debounce_timer = utime.ticks_ms()
      		# raise drip count
      		self.count += 1
      		# get byte value for variables (1 short 2 integers = 8 bytes)
      		byte_data = ustruct.pack('<HIH', self.event_count, drip_time, self.count)
      		# write byte value to file
      		self.rainfile.write("%s,%s,%s\n" % (self.event_count, drip_time, self.count))
      		# send byte value to LoRaWAN gateway
      		if self.networking:
      			self.send_byte_data(byte_data)
      		print('Johnny counted', self.count, 'tipped bucket(s) during event', self.event_count, 'after', drip_time, 's since the beginning of this epoch') # testing
      		# reset sleeper's timer to indicate ongoing rain event
      		self.reset_alarm()
      		machine.idle()
      def send_byte_data(self, byte_data):
      	# I tried with and without blocking ... same result
      	self.lorasocket.setblocking(True)
      	self.lorasocket.send(byte_data)
      	self.lorasocket.setblocking(False)
      Side note on raingage: gauge wakes up after the first bucket tipped and stays awake for 15 minutes to wait for further buckets. After 15 minutes without buckets it goes back to deepsleep to save battery time.
        loth4in
        Nevermind, I solved it.
        I'm new to real time programming and apparently had to find out the hard way not to put code that's too time consuming into an ISR. I changed it so that the ISR just changes a flag and that the actual work is being done in the main loop.
