    How do i know if am using NB-iot or Cat-m?
    lte
    2 Posts 2 Posters 234 Views 3 Watching
    • M Offline
      misterlisty
      This may be a silly question but im not sure what am using?
      • B Offline
        bqpd @misterlisty
        @misterlisty The way I understand it (correct me if I am wrong) is, that these are two very different LTE standards.
        LTE-M draws more current but is able to send data with 1 Mbit/s and 20ms latency whilst NB-IoT operates on 1000 times lower current on bands between 800 MHz-900MHz but can only send data with a lower bandwidth (250 Kbit/s) and a latency of 1s
        The main thing is availability in your country. Here in Germany only NB-IoT is available and LTE-M would need a whole new buildup of LTE infrastructure, NB-IoT works on the existing LTE network.
        So i guess you should check first, which standard is available in your country first.
