    SPI + MS5540C driver
    spisensorms5540c
    2 Posts 2 Posters 376 Views 2 Watching
    • B Offline
      BorbonJuggler
      Hello everyone,
      I am trying to write the driver for the MS5540C Miniature Barometer Module using SPI interface, I based my code in an existing arduino sketch. Nevertheless, I haven't managed to read from the sensor, which worked on the Arduino Uno without problem. I think the problem is in the phase and polarity value that have to be change during the reading sequence, in the Arduino SPI they just change SPI.setDataMode(SPI_MODE1) to SPI.setDataMode(SPI_MODE0) . I am not familiar with the SPI protocol, so I post my code looking for any insight in this matter.
      MS5540C.py:
      import ustruct
      from machine import SPI, PWM
      # SPI default pins for SCLK (CLK) , DIN(MOSI) and DOUT(MISO) (``P10``, ``P11`` and ``P14``)
      # MCLK signal with a frequency of 32.768KHz on P12
      pwm = PWM( 0, frequency=32768 )
      # 0 create pwm channel on pin P12 with a duty cycle of 50%
      pwm_c = pwm.channel ( 0, pin='P12', duty_cycle=0.5 )
      _RESET_SEQUENCE = bytearray ( [0x15, 0x55, 0x40] )
      _ADDRESS_WORD1 = bytearray ( [0x1D, 0x50] )
      _ADDRESS_WORD2 = bytearray ( [0x1D, 0x60] )
      _ADDRESS_WORD3 = bytearray ( [0x1D, 0x90] )
      _ADDRESS_WORD4 = bytearray ( [0x1D, 0xA0] )
      class MS5540C:
          def __init__( self ):
              #Calibration Word 1
              self.w1 = self.__read__calibration__word__( _ADDRESS_WORD1 )
              #Calibration Word 2
              self.w2 = self.__read__calibration__word__( _ADDRESS_WORD2 )
              #Calibration Word 3
              self.w3 = self.__read__calibration__word__( _ADDRESS_WORD3 )
              #Calibration Word 4
              self.w4 = self.__read__calibration__word__( _ADDRESS_WORD4 )
          def reset_sensor( self ):
              self.spi = SPI( 0, mode=SPI.MASTER, baudrate=500000, polarity=0, phase=0ze, firstbit=SPI.MSB )
              e = self.spi.write( _RESET_SEQUENCE ) # sent the byteds for _reset_sensor_
              if e != 3:
                  print('Error en Reset \n')
          def __read__calibration__word__ ( self, adress ):
              self.reset_sensor() # phase = 0
              # Calibration word request
              e = self.spi.write( adress ) #  Get Calibration word
              if e != 2:
                  print('Error en request Word \n')
              # Reading Calibration
              self.spi = SPI( 0, mode=SPI.MASTER, baudrate=500000, polarity=0, phase=1, firstbit=SPI.MSB )
              rbuf= self.spi.read(2)
              return  (rbuf[0] << 8) | rbuf[1]
      main.py:
      import time                   # Allows use of time.sleep() for delays
      import pycom                  # Base library for Pycom devices
      import ubinascii              # Needed to run any MicroPython code
      import machine                # Interfaces with hardware components
      import utime                  # Unix timestamp
      import micropython            # Needed to run any MicroPython code
      from machine import  Pin, Timer
      from MS5540C import MS5540C
      # Setup
      # Level sensor
      level_sensor = MS5540C()
      # FUNCTIONS
      # MAIN
      def main():
              print( "Word 1 is {}".format( level_sensor.w1 ) )
              print( "Word 2 is {}".format( level_sensor.w2 ) )
              print( "Word 3 is {}".format( level_sensor.w3 ) )
              print( "Word 4 is {}".format( level_sensor.w4 ) )
      main()
        tttadam
        hello there,
        Did you manage to solve this issue? :)
