    Can't connect Fipy via LTE NB-IoT to Pybytes
    3 Posts 2 Posters 486 Views 2 Watching
    • W Offline
      weingami
      Hello there, I tried to connect via NB-IoT to as described in this article , later I tried out this tip after I had no success, but it's still complaining with the same error message that it cannot connect to the MQTT server.
      Connecting to COM13...
      WMAC: 807D3AC2E464
      Firmware: 1.18.2.r3
      Pybytes: 0.9.10
      Initialed watchdog for WiFi and LTE connection with timeout 660000 ms
      LTE init(carrier=standard, cid=1)
      LTE attach(band=8, apn=iot.1nce.net, type=None)
      LTE connect()
      LTE is_connected()
      LTE connection established
      MQTTClient: Can't connect to MQTT server: "mqtt.pybytes.pycom.io"
      As a second connection preference
      was set to ["lte", "lora"]
      Any tips on how I could get this to work? Am I overlooking anything?
      • X Offline
        Xykon administrators @weingami
        @weingami Are you sure the operator you are using allows TCP (MQTT) connections to external platforms?
        Most NB-IoT network carriers don't support TCP and only allow UDP/CoAP connections to their own internal platforms.
        Christian Ehlers
        • W Offline
          weingami
          I was able to successfully connect via HTTPS to google and do a simple GET request, so it seemed. Though I don't do dabble around to often in network protocols. Would you have any suggestion for a safer way to determine whether our carrier supports UDP. The name of the carrier is 1NCE, btw.
