    LTE antenna not working on board
    fipylte
    7 Posts 3 Posters 507 Views 3 Watching
    • M Offline
      misterlisty
      When i use the fipy on a the extension board, the LTE works but on my PCB it doesnt work. Is there a LTE pin that should not be connected?
        robert-hh @misterlisty
        @misterlisty You can see at the FiPy Pin-Out which ins are needed by the LTE modem. its P15, P17 - P20. Besides LTE, does the FiPy seem to work fine?
        p.s.: I do not under stand "LTE antenna". The LTE antenna must be plugged to the FiPy, wherever you put the FiPy at.
        • M Offline
          misterlisty
          Fipy works fine. See the LTE commands..if i run this pycom from the extension board it work!
          -- START - INITILAISE LTE -------------------------------------------------------
          [ AT+SQNOMAHDEV? ] => ['', '+SQNOMAHDEV: 0,0,HUID0', '+SQNOMAHDEV: 0,1,HMAN0', '+SQNOMAHDEV: 0,2,HMOD0', '+SQNOMAHDEV: 0,3,HSW0', '+SQNOMAHDEV: 1,0,HUID1', '+SQNOMAHDEV: 1,1,HMAN1', '+SQNOMAHDEV: 1,2,HMOD1', '+SQNOMAHDEV: 1,3,HSW1', '', 'OK', '']
          | +SQNOMAHDEV: 0,0,HUID0 | +SQNOMAHDEV: 0,1,HMAN0 | +SQNOMAHDEV: 0,2,HMOD0 | +SQNOMAHDEV: 0,3,HSW0 | +SQNOMAHDEV: 1,0,HUID1 | +SQNOMAHDEV: 1,1,HMAN1 | +SQNOMAHDEV: 1,2,HMOD1 | +SQNOMAHDEV: 1,3,HSW1 | | OK | | [ AT+SQNOMAHDEV=? ] => ['', '+SQNOMAHDEV: (0-1),(0-3),"value"', '', 'OK', '']
          | +SQNOMAHDEV: (0-1),(0-3),"value" | | OK | | [ ATI1 ] => ['', 'UE5.0.0.0d', 'LR5.1.1.0-41065', '', 'OK', '']
          | UE5.0.0.0d | LR5.1.1.0-41065 | | OK | | None
          LTE set to
          +SQNCTM: telstra
          OK
          Feed hardware watchdog and blink..
          heatbeat suspended while BLE connected
          [ AT!="clearscanconfig" ] => ['', '', 'OK', '']
          | | OK | | [ AT+CGDCONT=1,"IP","telstra.m2m" ] => ['', 'OK', '']
          | OK | | [ AT!="addscanfreq band=28 dl-earfcn=9410" ] => ['', '', 'OK', '']
          | | OK | | [ AT+CEREG=2 ] => ['', 'OK', '']
          | OK | | [ AT+CFUN=1 ] => ['', 'OK', '']
          | OK | | Tones Done
          LTE Appear not be connected
          [ AT+COPS=? ] => ['', 'ERROR', '']
          | ERROR | | [ AT+CSQ ] => ['', '+CSQ: 99,99', '', 'OK', '']
          | +CSQ: 99,99 | | OK | | Attempting to attach to LTE ....... LTE successfully connected to network..
          LTE attached to
          +SQNCTM: telstra
          OK
          LTE RSSI: -83 dbM
          'InitCellular..done'
            SiMoS-IoT
            Not sure what you mean by "my PCB"...have you designed your own and if so, does it have all the necessary components to interface with the FiPy?
            • M Offline
              misterlisty
              If i just connect pin 1,2 on the pycom from my board, it still fails to connect. It must be the power supply. The pycom ext board is providing 5.0 volts, my board is suppylinh 4.82v. This MUST be the cuase..nothing else is different! Very weird?
                @misterlisty An input voltage of 4.82V is fine. The Vin range goes down to 3.6V, assumed, that the impedance of the power source is low. I have a home brew expansion board here with a polarity protection diode at Vin, and Vin is 4.65V. LTE works fine.
                If you have an oscilloscope, monitor the Voltage at Vin for short drops. Taking the power with a volt meter does not show fast fluctuations.
                What kind of LTE antenna are you using?
                • M Offline
                  misterlisty
                  Found the issue, appears like the pcb regulator causing the issue.
