MAJOR ISSUE: MQTT library blocking when Subscribe
When I'm running this simple code to connect to Thingsboard and subscribing to a topic,
the code doesn't run passed the call to the subscribe method (line 35):from mqtt import MQTTClient from network import WLAN import machine import time import config def settimeout(duration): pass def sub_cb(topic, msg): print(msg) wlan = WLAN(mode=WLAN.STA) wlan.antenna(WLAN.EXT_ANT) wlan.connect(config.WLAN_SSID, auth=(WLAN.WPA2, config.WLAN_Password), timeout=5000) while not wlan.isconnected(): machine.idle() print("\nConnected to WiFi") client = MQTTClient(client_id=config.MQTT_DEVICE_ID, server=config.MQTT_BROKER_ADDRESS,user=config.MQTT_DEVICE_TOKEN, password="", port=config.MQTT_BROKER_PORT) client.settimeout = settimeout client.connect() print("Connected to MQTT Broker\n") client.set_callback(sub_cb) client.subscribe(topic="v1/devices/me/attributes") time.sleep(1) client.publish(topic="v1/devices/me/telemetry", msg="{\"d\":\"OFF\"}") while True: print("Sending ON") client.publish(topic="v1/devices/me/telemetry", msg="{\"d\":\"ON\"}") time.sleep(1) print("Sending OFF") client.publish(topic="v1/devices/me/telemetry", msg="{\"d\":\"OFF\"}") client.check_msg() time.sleep(1)When triggering updates in Thingsboard, the device indeed gets the subscribed updates as shown in the terminal output:
b'{"AlwaysSendData":true}' b'{"AlwaysSendData":false}But the code never reach the while loop, looks like the subscribe method are blocking(!?)
When idle for a few minutes, the code exits whit the following message:Traceback (most recent call last): File "/flash/main.py", line 35, in <module> File "/flash/lib/mqtt.py", line 142, in subscribe File "/flash/lib/mqtt.py", line 161, in wait_msg OSError: -1 Pycom MicroPython 1.18.2.r3 [v1.8.6-849-a1641ca] on 2019-02-28; FiPy with ESP32 Type "help()" for more information. >>>If I exclude the subscribe call, the loop suns as expected and updates reaches Thingsboard.
Running similar code in Arduino IDE on a Wemos Lolin ESP32 device works just fine, so it's not an issue with Thingsboard.
ANY help would be much appreciated to fix this issue, it's a showstopper for my (commercial) project! -
Hi! Did you manage to resolve this issue? I'm facing it too and would appreciate if any kind soul can assist.
Hi, did this ever get resolved? I think I'm seeing the same issue...
@Siridar Hello, did you find the solution? I'm now at the same point
Regards -
Hello, Did you find the solution? I faced with the same issue
