    method to return if lora.nvram is available
    nvramrestorelorawanlopy
    4 Posts 2 Posters 386 Views 2 Watching
    • philwilkinsonP Offline
      philwilkinson
      When a device has rebooted from a deepsleep, is there a simple method to check if lora.nvram_save() was implemented and can be used with lora.nvram_restore()?
      line 3 in the sample code below is what I am trying to achieve, however calling lora.nvram_restore() does not return a value, so it cannot be used.
      Any ideas?
      from network import LoRa
      if lora.nvram_restore(): #I want to do something like this
          while not lora.has_joined():
              time.sleep(0.5)
          lora = LoRa(mode=LoRa.LORAWAN, region=LoRa.AU915, adr=False, tx_retries=0, device_class=LoRa.CLASS_A)
          appeui = binascii.unhexlify(app_eui)
          appkey = binascii.unhexlify(app_key)
          lora.join(activation=LoRa.OTAA, auth=(appeui, appkey), timeout=0)
      s.setblocking(True)
      s.send("some data")
      s.setblocking(False)
      rev_data = s.recv(64)
      print('recieved data: ', rev_data)
      lora.nvram_save()
      machine.deepsleep(some_time)
        Asb
        If you start by calling nvram_restore, you can check using lora.has_joined(), if lora.navram_save() was successfully saved, lora.has_joined() will return true
        philwilkinsonP 1 Reply Last reply Reply Quote 1
          philwilkinson @Asb
          @Asb thanks for the response.
          As you can see from the code, I am using lora.has_joined() method. However lora.has_joined() takes some time to connect and return True, also the time it takes to connect is not predictable.
          I hoped to call a method that immediately returned a Boolean to reduce time 'wasted' waiting to connect when nvram_save() was never used.
            philwilkinson
            OK @Asb comment got me thinking that everyone seems to be fine with the lora.has_joined() method call.
            So I put a slight delay following the nvram_restore call, and it seems to work ok. 2 seconds seems to be optimal.
            This code seems to work most of the time.
                time.sleep(2)
                if not lora.has_joined():
                    print('failed to join via nvram_restore')
                    for i in range(16, 65): #AU915 TTN gateways need channels removed
                        lora.remove_channel(i)
                    for i in range(66, 72):
                        print('trying to join OTAA')
                        time.sleep(0.5)
                    print('connected and ready to publish')
                s.setblocking(True)
                s.send("some data")
                lora.nvram_save()
                time.sleep(2)
