    how to check if a non-existing key in nvs ?
    dictkey valuenvsnvsget
    13 Posts 7 Posters 912 Views 7 Watching
    • philwilkinsonP Offline
      philwilkinson
      How can I check if a key value pair dict is saved in NVS?
      def car_count():
          if pycom.nvs_get('count'):
              pycom.nvs_set('count', (pycom.nvs_get('count')+1))
              print('{} cars have passed so far this period'.format(pycom.nvs_get('count')))
          else:#needed following initial start up
              pycom.nvs_set('count', 1)
              print('first car passed this way')
      according to the docs if a non-existing key is given the returned value will be None. However I get an error
      ValueError: No matching object for the provided key
        johand
        You have to check if it is None or not, change to:
        if pycom.nvs_get("count") != None:
        P 2 Replies Last reply Reply Quote 0
          philwilkinson
          it returns the same error
            johand @philwilkinson
            @philwilkinson Any reference to a line? I just tried your code and it works fine for me.
              philwilkinson
              I was just using the REPL and it returned the error when I called nvs_get('count').
                @philwilkinson No problem when I try, are you using an old firmware?
                  philwilkinson
                  It is a bug. I have raised issue #306 on Github
                  On the latest firmware
                  Pycom MicroPython 1.18.2.r7 [v1.8.6-849-df9f237] on 2019-05-14; LoPy4 with ESP32
                  >>> import pycom
                  >>> pycom.nvs_get('anything')==None
                  so I used a previous version of the firmware
                  Pycom MicroPython 1.18.2.r2 [v1.8.6-849-5cf02dc] on 2019-03-07; LoPy4 with ESP32
                  >>>import pycom
                  True
                    PeterB @johand
                      PeterB @johand
                      @johand said in how to check if a non-existing key in nvs ?:
                      Are you sure that will work? An exception is an exception and "pycom.nvs_get("count")" would not return anything to compare with. The exception would be generated before the compare can be executed.
                        crumble @PeterB
                        @PeterB said in how to check if a non-existing key in nvs ?:
                        Depends on the version. This must have changed over time.
                        You can simply use a variable and wrap the call, so that it shall run on all versions:
                        try:
                            _wake = pycom.nvs_get('wake');
                        except Exception as e:
                            _wake = None
                        if _wake==None:
                            _wake = 103
                        John BairdJ 1 Reply Last reply Reply Quote 0
                        • John BairdJ Offline
                          John Baird @crumble
                          @crumble I just ran into this today. Yes, I agree you can wrap the call and catch the exception - however, the current documentation states "If a non-existing key is given the returned value will be None." (See: https://docs.pycom.io/firmwareapi/pycom/pycom/). The general catching of unknown exceptions isn't good practice. While I think your workaround is sound, I'd upvote this as a bug that needs to be fixed.
                            thibault
                            in our code we use a such function to read memory:
                            def memory_get(name='MIR', default_value=1):
                                ''' Retourne une valeur par défaut si la mémoire NVS
                                ne contient pas l'élément recherché '''
                                try:
                                    _value = pycom.nvs_get(name)
                                except Exception:
                                    _value = None
                                if _value is None:
                                    _value = default_value
                                return _value
                            I'm not sure if that is the python way, but maybe that can help you!
                            • M Offline
                              Michael Baker
                              the_value = pycom.nvs_get('the_key',None)
                              if the_value:
                                  print(the_value)
