    Launching pybytes (pybytes autostart set to off)
    2 Posts 2 Posters 715 Views 2 Watching
    • H Offline
      HansSanitizer
      I was wondering if there was a command to launch Pybytes manually from within a script, after having the device start up with pybytes disabled.
        jirkakrepl
        there is, we have function pybytes.start()
        You will need to instantiate pybytes object manually. Basically do the steps that this code is doing, when pybytes_autostart is True. https://github.com/pycom/pycom-micropython-sigfox/blob/pybytes-master/esp32/frozen/Base/_main.py#L21-L45
        >>> from _pybytes_config import PybytesConfig
        >>> pybytes_config = PybytesConfig().read_config()
        >>> from _pybytes import Pybytes
        >>> pybytes = Pybytes(pybytes_config)
        this is how the full output if pybytes_autostart was false and how I manually connected to Pybytes later.
        (you can see the message: Not starting Pybytes as auto-start is disabled)
        configsip: 0, SPIWP:0xee
        mode:DIO, clock div:1
        load:0x3fff8028,len:8
        load:0x3fff8030,len:1688
        load:0x4009fa00,len:0
        load:0x4009fa00,len:14592
        entry 0x400a059c
        Pycom MicroPython 1.18.2.r6 [v1.8.6-849-a210e85] on 2019-05-13; WiPy with ESP32
        WMAC: 240AC40B3A1C
        Firmware: 1.18.2.r6
        Pybytes: 0.9.12
        >>> pybytes.connect()
        Initialized watchdog for WiFi and LTE connection with timeout 660000 ms
        WiFi connection established
        WARNING: consider enabling TLS by using pybytes.enable_ssl()
        Connected to MQTT 10.0.0.66
        Pybytes connected successfully (using the built-in pybytes library)
        software developer @ Pycom
