    Reading from a Polar H7 Bluetooth Heartrate sensor
    3 Posts 2 Posters 1.6k Views 2 Watching
      arneme
      I have tried to connect to and read the pulse data from a Polar H7 sensor but is not managing to get it to work. Any ideas?
      The error I get is:
      Got services...
      Reading from service 180d
      Print chars found
      char 2a37
      Reading pulse data every second...
      Exception caught...
      the requested operation failed
      Here is the code:
      from network import Bluetooth
      bt = Bluetooth()
      bt.start_scan(-1)
      # Code to connect to Polar H7 Bluetooth heartrate sensor
      # The detected Heartrate is "published" over the LoRaWAN network
          adv = bt.get_adv()
          if adv:
              name = bt.resolve_adv_data(adv.data, Bluetooth.ADV_NAME_CMPL)
              if name is not None:
                  if name.startswith("Polar H7"):
                      print ("Found: " + name)
                      bt.stop_scan()
                      try:
                          conn = bt.connect(adv.mac)
                          print("Connected...")
                          services = conn.services()
                          print("Got services...")
                          for service in services:
                              time.sleep(0.05)
                              # According to specification from Polar, service.uuid = 0x180D is Heart Rate and char.uuid = 2a37 is value in beats per minutes
                              if service.uuid() == 0x180D:
                                  print('Reading from service %x' % service.uuid())
                                  chars = service.characteristics()
                                  print("Print chars found")
                                  for char in chars:
                                      print('char %x' % char.uuid())
                                      # Charactersistic 2a37 is a notification char and we need to enable notification to receive the ValueError
                                      if char.uuid() == 0x2a37:
                                          # Notify sensor that we want to receive pulse data.
                                          byte = bytes([1])
                                          char.write(byte)
                                              print("Reading pulse data every second...")
                                              print('char {} value = {}'.format(char.uuid(), char.read()))
                      except Exception as ex:
                          print("Exception caught...")
                          print(ex)
        jmarcelino @arneme
        @arneme
        The Heart Rate Measurement profile requires BLE notifications, it doesn't work with simple reads.
        However there isn't yet a system to receive BLE notifications on the LoPy so unfortunately you'll have to wait a bit more.
        EDIT: Was catching up on the other threads and apparently this functionality could come next week. I also have a Polar H7 and can look into it at some point.
          arneme
          I was afraid that the notification part was missing in the firmware but great if it appears soon :-). Thanks for the speedy reply.
