    SecureBoot and Encryption
    3 Posts 2 Posters 369 Views 2 Watching
      tom.mcadam
      I am having trouble following the instructions for SecureBoot and Encryption.
      Firstly there is a bit of confusion between secure-bootloader-key.bin and signature_verification_key.bin, I think they are the same thing and this is just a typo?
      When I run :
      # Burning Encryption Key python $IDF_PATH/components/esptool_py/esptool/espefuse.py --port /dev/ttyUSB0 burn_key flash_encryption flash_encryption_key.bin. I am getting an error that the block is already write protected. This is the same with 3 brand new WiPys. The blocks look like this in the efuse summary.
      When I try and run:
      # Burning Secure Boot Key python $IDF_PATH/components/esptool_py/esptool/espefuse.py --port /dev/ttyUSB0 burn_key secure_boot secure-bootloader-key.bin, I'm getting an error that a 32 byte key is required. The secure-bootloader-key.bin is 64 bytes, so I guess this error is justified. In espsecure.py (which generates this)it looks like this should be a 256bit key, so I'm not sure were this coming from.
      Grateful of any help. I have a few attempts at this workflow and had no luck.
        johand
        I had the same problem, at least the key length problem. I don´t remeber exactly the solution for the problem. But look at my notes below how to generate the keys and flash the device, you should be able to get it up and running with these commands.
        Johan
        python $IDF_PATH/components/esptool_py/esptool/espsecure.py generate_flash_encryption_key flash_encryption_key.bin
        python $IDF_PATH/components/esptool_py/esptool/espsecure.py generate_signing_key secure_boot_signing_key.pem
        python $IDF_PATH/components/esptool_py/esptool/espsecure.py extract_public_key --keyfile secure_boot_signing_key.pem signature_verification_key.bin
        sudo python $IDF_PATH/components/esptool_py/esptool/espefuse.py --port /dev/ttyS6 burn_key flash_encryption /path/to/flash_encryption_key.bin
        make SECURE=on SECURE_KEY=/path/to/secure_boot_signing_key.pem ENCRYPT_KEY=/path/to/flash_encryption_key.bin TARGET=boot
        make SECURE=on SECURE_KEY=/path/to/secure_boot_signing_key.pem ENCRYPT_KEY=/path/to/flash_encryption_key.bin TARGET=app
        sudo python $IDF_PATH/components/esptool_py/esptool/espefuse.py --port /dev/ttyS6 burn_key secure_boot secure-bootloader-key.bin
        sudo python $IDF_PATH/components/esptool_py/esptool/espefuse.py --port /dev/ttyS6 burn_efuse FLASH_CRYPT_CNT
        sudo python $IDF_PATH/components/esptool_py/esptool/espefuse.py --port /dev/ttyS6 burn_efuse FLASH_CRYPT_CONFIG 0x0F
        sudo python $IDF_PATH/components/esptool_py/esptool/espefuse.py --port /dev/ttyS6 burn_efuse ABS_DONE_0
        sudo python $IDF_PATH/components/esptool_py/esptool/esptool.py --chip esp32 --port /dev/ttyS6 --baud 921600 --before no_reset --after no_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size detect 0x0 build/WIPY/release/bootloader/bootloader.bin 0x8000 build/WIPY/release/lib/partitions.bin_enc 0x10000 build/WIPY/release/wipy.bin
        T 1 Reply Last reply Reply Quote 1
          tom.mcadam @johand
          @johand Sorry for the delay. I just got back around to this today, and had a win with your commands :).
          Thanks for your help!!
