    Socket timeout not honored with SSL
    1 Posts 1 Posters 203 Views 1 Watching
      ccarreiras
      Has anyone faced issues with socket timeouts when using HTTPS connections?
      System information:
      sysname='GPy'
      nodename='GPy'
      release='1.18.2.r7'
      version='v1.8.6-849-df9f237 on 2019-05-14'
      machine='GPy with ESP32'
      When configuring a socket to use a timeout, if the socket has been wrapped with the ussl.wrap_socket method, the timeout is not honored.
      Given a socket sock which has been successfully connected to a host, trying to call sock.read should return None if the timeout is reached and there is nothing to read in the socket:
      import usocket
      sock = usocket.socket()
      sock.settimeout(5)
      sock.connect((host, port))
      t = sock.read(1)
      # after timeout, t is None
      print(t is None)
      But when the socket is wrapped with ussl, the timeout setting is ignored and read blocks forever:
      import usocket
      import ussl
      sock = ussl.wrap_socket(sock)
      sock.settimeout(5)
      # this hangs indefinitely
      t = sock.read(1)
      This also happens at least for the readline method.
      Take a look at this issue on Github:
      https://github.com/pycom/pycom-micropython-sigfox/issues/315
