    LoRaWAN network
    21 Posts 4 Posters 9.1k Views 5 Watching
      gouao
      I am worried about my lorawan network security. What will happen if there is another lorawan network nearby ?
      How would I know that the owner of the nearby network will not be able to enter in mine ?
      Does it have a lora SSID, or only a wifi SSID ?
      I will really be grateful if you could help me.
      All the best
      bmarkusB G 2 Replies Last reply Reply Quote 0
      • bmarkusB Offline
        bmarkus @gouao
        @gouao said in LoRaWAN network:
        All the best
        In the LoRaWAN network both MAC (network control communication between your device and network server) and user data are encrypted by different 128-bit AES keys. Normally each device has a unique key set even in the same network server and account. Depending of the configuration, application encryption key may be unknown for the network server. So in general LoRaWAN offers proper protection for nearly all applications.
          jmarcelino
          It's not an SSID but - to put it simply - LoRaWAN uses two unique keys to encrypt communication so only your node and your network server will understand whats being sent.
          If you're interested in the details this is a good white paper https://labs.mwrinfosecurity.com/assets/BlogFiles/mwri-LoRa-security-guide-1.2-2016-03-22.pdf
            gouao
            Thanks both of you, I understand way better the security issue I was facing !
            Concerning the link, I already found some useful informations out there. ;)
            I'm planning to communicate 2 LoPy devices thanks to the OTAA Join procedure in order to create a LoRaWAN network, but I'm not sure where I should start, and what might be the right way to achieve my goal.
            I found something that might help here : https://docs.pycom.io/pycom_esp32/library/network.LoRa.html# & https://docs.pycom.io/pycom_esp32/pycom_esp32/lora_examples.html#lora-loramac
            What could be done with those samples, and how would be the better way to use them ?
            Thanks.
            bmarkusB 1 Reply Last reply Reply Quote 0
            • bmarkusB Offline
              bmarkus @gouao
              Do you mean to create a LoraWAN network built of the 2 LoPy-s or you want to connect the 2 LoPy devices to an existing LoRaWAN network via nearby third-party gateway?
                gouao @bmarkus
                @bmarkus To create a LoraWAN network build of the 2 loPys
                  jmarcelino @gouao
                  @gouao
                  It's not (yet?) possible to create LoRaWAN networks that support OTAA joins with just 2 LoPys.
                  True LoRaWAN networks require a LoRaWAN gateway, a special device which has powerful dedicated radio chip able to listen on multiple frequencies at the same time, amongst other things. These cost $200+.
                  There are some tricks to mimic some gateway functionality using LoPys but those aren't really sufficiently developed yet.
                  For now you can look for nearby LoRaWAN gateways, maybe someone already has one you can use or you can setup your own. For example check the Thing Network https://www.thethingsnetwork.org which is a public network by volunteers open to everyone.
                  Alternatively you can use 'raw' LoRa (i.e. without the WAN protocol) to communicate between your LoPys, for example using the Nano gateway example https://forum.pycom.io/topic/236/lopy-nano-gateway
                    gouao @gouao
                    @gouao Is that possible to create a LoRaWAN network using LoraMAC instead of OTAA join tho ?
                    I understand better how does it work, thanks !
                    The solution you proposed on TTN webbsite seems nice, i'll dig on it.
                    So, how my LoRaWAN network will work once the gateway will be able to listen the LoPys ? Would I need to pass through a server then, only to make my LoPys devices communicate ?
                      jmarcelino @gouao
                      @gouao
                      Yes, LoRaWAN requires a network server even for just 2 devices. Also it's not meant for devices communicating between themselves, it's more for having many devices uploading small amounts of data to some server.
                      For device to device there's LoRa mode (without the WAN), which is essentially just a radio channel, like a walkie-talkie. But remember you need to do your own encryption then and probably establish some sort of protocol.
                        gouao @jmarcelino
                        @jmarcelino Sure, the devices communicating between themselves case was for some tests.
                        How this server scenario actually works ? The planning will consist to send data to this server.
                        So the LoRa mode is certainly working on low frequency ? Do you know the range of this mode please ?
                        Furthermore, what could be the etablishment of my own encryption ? Some code to add in the boot.py ?
                        Do you have any code samples wich could help me on this, and for the LoRaWAN network ?
                          jmarcelino @gouao
                          @gouao
                          I suggest reading a few things on LoRaWAN such as https://www.thethingsnetwork.org/wiki/LoRaWAN/Home and also this crash-course video https://www.youtube.com/watch?v=T3dGLqZrjIQ
                          It's difficult to say a range with anything radio, it depends on your environment, but my best with LoRa was 5 Kilometres using SF12, no line of sight and the receiver located at an altitude of 8 meters
                          For encryption of LoRa data you could use for example AES, see https://docs.pycom.io/pycom_esp32/library/ucrypto.AES.html
                          then just make sure both LoPys have the same key.
                          I don't have any LoRa samples sorry, but the nano gateway example I linked below and the LoRa-MAC (Raw LoRa) in the Pycom tutorial should explain it.
                          G bmarkusB 2 Replies Last reply Reply Quote 0
                            gouao @jmarcelino
                            @jmarcelino It's very kind of you, I will dig on this side !
                            May I return to you if I still have questions ?
                            Thanks for all.
                            • bmarkusB Offline
                              bmarkus @jmarcelino
                              @jmarcelino said in LoRaWAN network:
                              With line of sight we have stable link in 50-60 km where S/N is around 0dB which means there is plenty of spare link budget down to -18dB. Conditions:
                              • 868 MHz
                              • Kerlink professional gateways
                              • SF12
                              • Simple omni-directional antenna
                              Record is cca. 150 km distance. In a city like Budapest from car with antenna on the roof 20-25km usually works with Kerlink gateways.
                              On 434 MHz with P2P using SX127x chips, not SX130x we have seen 60km link, on a bicycle tracking it gives 10-12km reliable tracking with stable station just in a house, no hilltop, towers, etc.
                                gouao @bmarkus
                                @bmarkus said in LoRaWAN network:
                                • 868 MHz
                                • SF12
                                Wow, thanks ! Can you estimate the price of such a project ?
                                  jmarcelino @gouao
                                  @gouao
                                  It's not really a question of price, but 99% about antenna positioning - especially what's around the antennas - on both nodes and gateways.
                                  You can easily spend $1000+ on a gateway and not get much more than 1Km.
                                  Line of sight and antenna height are particularly important. The video I linked explains a lot about that.
                                  • bmarkusB Offline
                                    bmarkus @jmarcelino
                                    @gouao
                                    People tend to forget LoRa is RADIO technology which need ANTENNA and proper POSITIONING, not only software. A proper antenna can make miracles. However we see better performance using a Kerlink GW over RPi even they have the same chipset. Frontend filters can improve performance on receiving side. By experience the latest Kerlink station outperforms current generation according to our tests. So for higher price you get better performance. But true, you can reach poor performance for high price also with improper installation, noisy environment, etc.
                                      gouao @jmarcelino
                                      @gouao
                                      True, the vid explains a lot about it, and underlines points like antenna height, reflection & diffraction phenomenon.
                                      Any ideas how could I configure a server for a LoRaWAN network, wich will probably work with a TTN gateway please ?
                                        jmarcelino @gouao
                                        @gouao
                                        If you mean running a server for your own private LoRaWAN network (outside of Things Network) you can try https://github.com/brocaar/loraserver
                                        The other alternative - and the way I'm using - is to run you own copy of Things Network, it's fully open source and they even provide a setup guide at https://www.thethingsnetwork.org/article/setting-up-a-private-routing-environment - but you should really understand how their system works first.
                                        • bmarkusB Offline
                                          bmarkus @jmarcelino
                                          @gouao
                                          You can use a Loriot server also, which is free for 1 GW and up to 10 devices, see https://loriot.io/
                                            gouao
                                            Thanks both of you !
                                            • 1
                                            • 2
                                            • 2 / 2
