to get the CSQ
  • Dear sir/mam,
    Could anyone please help me how can I get the CSQ of my network signal and how would I know that my board is connected the network?
    How can run the AT commands.
    Waiting for your positive reply.
    radhe
  • Global Moderator
    @radheshyam0508 Look at the example in the documentation:
    https://docs.pycom.io/tutorials/lte/nb-iot/
    which is similar to my little script I posted before. After connection, I tried a simple connection link to a PC I had set up as the server:
    data_client = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
    ip_address="84.147.45.246"
    port_number = 4567
    data_client.connect((ip_address, port_number))
        msg = input("New message")
        if msg == "q":
            break
        data_client.send(msg + "\r\n")
    data_client.close()
    I lost somehow the code of the matching "server", but it was minimal. I may have type that on-the-fly at a Python REPL.
  • @robert-hh
    sorry, but How would i know that my device is connected?
  • Global Moderator
    @radheshyam0508 Once the device is attached and connected, you can use the usual socket mechanism to communicate.
  • @robert-hh said in to get the CSQ:
    lte.attach()
    lte.send_at_cmd("AT+CSQ")
    Thanks a lot Robert,
    Could you please send me the code for connecting the fipy NB-IoT module to the network.
    Because there is no tutorial or example code for NB-IoT.
    Thanks a lot for your help and support
  • Global Moderator
    @radheshyam0508 You could try this:
    from network import LTE
    lte=LTE()
    lte.attach()
    Returns for me:
    '\r\n+CSQ: 25,99\r\n\r\nOK\r\n'
    lte.isattached()
    returns the attach status. A typical small test script would be:
    start = time.ticks_ms()
    lte = LTE()
    print("\nModem started, time needed (s): ", time.ticks_diff(time.ticks_ms(), start)/1000)
    lte.attach(band=8, apn="iot.1nce.net")
    while not lte.isattached():
        time.sleep(0.5)
        print(".", end="")
    print("\nAttached!, time needed (s): ", time.ticks_diff(time.ticks_ms(), start)/1000)
    lte.connect()       # start a data session and obtain an IP address
    while not lte.isconnected():
        time.sleep(0.5)
        print("-", end="")
    print("Connected!, time needed (s): ", time.ticks_diff(time.ticks_ms(), start)/1000)
