urequest.post gives me an OSError: Network card not available
Hi all!
I simply like to post some measurement values to an influxdb.resp_data = "current,location={0} value={1}".format(location, irms) resp = urequests.post(db, data=resp_data) print("response: {}".format(resp.status_code))I'm using the lates urequests.py from micropython-lib.
The error points me to line 56 of the urequests.py lib
s = usocket.socket(ai[0], ai[1], ai[2])Someone else getting such an error?
Cheers,
Thomas -
Ok...
Digging a bit deeper into the problem.The request method in urequests.py uses the usocket.getaddrinfo method from the usocket lib to resolve the host ip.
The given ip string isdb = "http://xxx.xxx.xxx.xxx:8086/write?db=energy_db"and it is splittet correctly.
The result of the usocket.getaddrinfo callai = usocket.getaddrinfo(host, port, 0, usocket.SOCK_STREAM)gives the following list back:
[(2, 1, 0, '', ('xxx.xxx.xxx.xxx', 8086))]The first list entry is the 'family'. Locking into the docs, FamilyType[2] is socket.AF_SIGFOX.
The L01 doesn't have a SIGFOX modem. So, to try to open a socket withs = usocket.socket(ai[0], ai[1], ai[2])leads to the OSError: Network card not available.
I'm using Pycom 1.20.0.rc13 [v1.9.4-94bb382] firmware. Is it probably a bug?
Cheers,
Thomas -
urequests.request("POST","http://IPADDRESS/api/v1/TOKEN/telemetry","{\"temperature\": 25.01,\"pressure\": 1.02}", None, {"Content-Type": "application/json"},None).textThis worked for me to post to thingsboard
after changing
ai = usocket.getaddrinfo(host, port, 0, usocket.SOCK_STREAM)to
ai = usocket.getaddrinfo(host, port)But when I got an error I had to power off to make it work again.
release='1.18.2.r7'
@KenM Could you please share the python code I am trying to send data to thingsboard via Gpy LTE Nb network.
@KenM said in urequest.post gives me an OSError: Network card not available:
api/v1/
thanks lot .it is working...
