    valid values for lte = LTE(carrier="xxx")?
    10 Posts 5 Posters 897 Views 5 Watching
      poesel
      I'm in Germany and have a hologram card. It should be supporting 'vodafone' & 'telekom' here..
      The first doesn't work (not attaching but this may be a different problem). The second gives me wrong carrier.
      So what are the valid carriers?
      P R 2 Replies Last reply Reply Quote 0
        poesel @poesel
        Hello @administrators - this is a quite direct question that should be answerable easy enough if you look in the source code.
        Sorry if its in the documentation. Then I have missed it and would be happy about pointers.
        • B Offline
          Bettina administrators
          Hi Poesel,
          You should be asking Hologram please. While we're happy to support on our products, we don't have anything to do with how their service is configured on the SIM cards/their backend. However, we suspect could be because there's no agreements on NB-IoT between them and Vodafone. NB-IoT works differently to CAT-M1. As a Vodafone reseller ourselves, we have had to do a fair amount of integration work. SIMs will be available soon.
          Best wishes
          Bettina
          Bettina
          Pylot at Pycom
          • R Offline
            rskoniec @poesel
            @poesel Do you know if / which technology (NB1/M1) each of your local carrier is using? I assume that you are aware of the fact that you must also have appropriate modem f/w version (NB1/M1) installed on your FiPy/GPy.
              poesel
              Thanks for the answer but now I'm confused. When I create the LTE object how can I get a 'wrong carrier' fault if I'm not yet connected to a network?
              This is why I thought that there is a list of valid carriers in the firmware.
              robert-hhR R 2 Replies Last reply Reply Quote 0
                robert-hh @poesel
                @poesel To determine the proper carrier, the firmware issues the following command to the modem:
                AT+SQNCTM=?
                You can do so too. As a side note, I do not specify the carrier at all. When I issue the command, I get the following list:
                >>> from network import LTE
                >>> lte=LTE()
                >>> lte.send_at_cmd("AT+SQNCTM=?")
                '\r\n+SQNCTM: ("3gpp-conformance", "ais", "aptg", "att", "bell", "cht", "cta", "dialog", "dish", "docomo", "dtag", "etisalat", "kddi", "kpn", "kt", "lgu", "orange", "singtel", "skt", "softbank", "spark", "standard", "swisscom", "telenor", "telstra", "tmo", "truphone", "turkcell", "verizon", "vodafone")\r\n\r\nOK\r\n'
                This looks like the list for supported carriers. So there is vodafone and dtag (Deutsche Telekom AG) in the list.
                • R Offline
                  rskoniec @poesel
                  @poesel said in valid values for lte = LTE(carrier="xxx")?:
                  When I create the LTE object how can I get a 'wrong carrier' fault if I'm not yet connected to a network? [...]
                  According to the docs:
                  lte.init(*, carrier=None)
                  This method is used to set up the LTE subsystem. After a deinit() this method can take several seconds to return waiting for the LTE modem to start-up. Optionally specify a carrier name. The available options are: verizon, at&t, standard. standard is generic for any carrier, and it’s also the option used when no arguments are given.
                    robert-hh @rskoniec
                    @rskoniec Actually the carrier is checked by the code against the list of carriers returned by the AT+SQNCTM=? command (see below).
                    Edit: I tested that with carrier="dtag". No difference to not specifying the carrier at all.
                      poesel
                      Thanks all! Question answered.
                        Jorge Romero @rskoniec
                        Hi @rskoniec @robert-hh, I would like to know if is possible to fix it or maybe if there is something wrong, because when I want to determine the proper carrier on my Fipy, I did not get any response, the list is empty.
                        The firmware version is LR5.1.1.0-47510 and it is in application mode. Thank you in advance.
                        >>> lte=LTE()
