Problem on updating Expansion board V3.1
Hello All,
I am new to this community and also with Pycom. I'm trying to set up my loppy4 with expansion board 3.1 and followed the instruction. I already downloaded the latest firmware dfuc file (expansion31_0.0.11.dfu). I downloaded Macport and excode also. When I try to run sudo dfu-util -D expansion31_0.0.11.dfu within 7sec after press S1 and plug usb...it results in below...
Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc.
Copyright 2010-2016 Tormod Volden and Stefan Schmidt
This program is Free Software and has ABSOLUTELY NO WARRANTY
Please report bugs to http://sourceforge.net/p/dfu-util/tickets/Match vendor ID from file: 04d8
Match product ID from file: ef99
Opening DFU capable USB device...
ID 04d8:ef99
Run-time device DFU version 0100
Claiming USB DFU Runtime Interface...
dfu-util: Cannot set alt interface zeroPlease advise how to solve this. Thank you!
The problem is...
as per instruction...it should result on below...
dfu-util 0.9
Match product ID from file: f014
ID 04d8:f014
Determining device status: state = dfuIDLE, status = 0
dfu-util: WARNING: Runtime device already in DFU state ?!?
Claiming USB DFU Interface...
Setting Alternate Setting #0 ...
dfuIDLE, continuing
DFU mode device DFU version 0100
Device returned transfer size 64
Copying data from PC to DFU device
Download [=========================] 100% 16384 bytes
Download done.
state(2) = dfuIDLE, status(0) = No error condition is present
Done! -
@hiyasbie Check this thread Expansion board 3.1 issues
@rskoniec Thank you for checking this out. I am using my macbook pro with the problem. My friends has a laptop (Windows) which he used to update his expansion board successfully. When I tried to update my expansion board on his laptop, it was successful...Would this mean that m expansion board is already updated? can I used it on my macbook? Thank you very much for your reply.
Hi @hiyasbie, I'm having the same issue on my MacBook Air. Were you able to update your firmware using your MacBook Pro or was your workaround solution just use your friend's laptop w/Window's to update your expansion board?
I have the same issue on a macbook when trying to update the Pytrack module:
ID 04d8:f014
dfu-util: Cannot set alt interface zero -
@astro @hiyasbie
I was also able to reproduce on a macOS 10.15.1. Sometimes executing the command withsudo dfu-util -D expansion31_0.0.11.dfuhelps.
Most likely, this due to some new Security & Privacy feature.Just to mention, it's not related to Expansion v3.1 manufacturing issues.
@hiyasbie quite complex answer
Am I missing the solution in this post? I still can't seem to update the board.
As Catalin mentioned, the issue is with MacOS, any other operating system should work fine!
Sorry to reply to an older thread. The dfu-util problem was caused by a bug in libusb, that only occurs on macOS in libusb 1.0.23 or 1.0.24. Either downgrade to libusb 1.0.22, or upgrade to 1.0.25 (once that becomes available), or use a different platform (Linux or Windows).
Thanks a lot, @macfreek!
This worked for me on mac catalina
brew unlink libusb
brew unlink dfu-util
brew install libusb --HEAD
brew install dfu-util --HEAD -
@Andrew-Sinclair said in Problem on updating Expansion board V3.1:
brew unlink libusb
brew install dfu-util --HEADusing my old macAir with HighSiera, this solved the problem
I had to 'brew uninstal'l the packages, unlink was not enough.
libusb was installed with an extra patch.==> Installing dependencies for libusb: m4, autoconf, automake and libtool ==> Installing libusb dependency: m4 ==> Patching ==> Applying secure_snprintf.patch patching file lib/vasnprintf.c Hunk #1 succeeded at 4858 (offset -11 lines). ==> ./configure --prefix=/usr/local/Cellar/m4/1.4.18libusb: stable 1.0.24, HEAD
dfu-util installed without problems
and the result is:Rainers-MacBook-Air% dfu-util -D pysense_0.0.8.dfu dfu-util 0.10-dev Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc. Copyright 2010-2021 Tormod Volden and Stefan Schmidt This program is Free Software and has ABSOLUTELY NO WARRANTY Please report bugs to http://sourceforge.net/p/dfu-util/tickets/ Match vendor ID from file: 04d8 Match product ID from file: f011 Deducing device DFU version from functional descriptor length Opening DFU capable USB device... Device ID 04d8:f011 Device DFU version 0100 Claiming USB DFU (Run-Time) Interface... Setting Alternate Interface zero... Determining device status... DFU state(2) = dfuIDLE, status(0) = No error condition is present dfu-util: WARNING: Device already in DFU mode? (bState=2 dfuIDLE) Claiming USB DFU Interface... Setting Alternate Interface #0 ... Determining device status... DFU state(2) = dfuIDLE, status(0) = No error condition is present DFU mode device DFU version 0100 Device returned transfer size 64 Copying data from PC to DFU device Download [=========================] 100% 16384 bytes Download done. DFU state(2) = dfuIDLE, status(0) = No error condition is present Done!
