ussl.wrap_socket results in OSError: [Errno -1] ERR_MEM
Hi all,
I'm stuck on a problem which does not occur in python on PC:import ussl, socket s=socket.socket() s.setsockopt(socket.SOL_SOCKET,socket.SO_REUSEADDR,1) s.bind(('0.0.0.0',443)) s.listen(16) conn, addr = s.accept()gives the follwowing output with curl:
daniel@trias:~$ curl -v -k https://192.168.4.1 * Expire in 0 ms for 6 (transfer 0x55aafe83ff30) * Trying 192.168.4.1... * TCP_NODELAY set * Expire in 200 ms for 4 (transfer 0x55aafe83ff30) * Connected to 192.168.4.1 (192.168.4.1) port 443 (#0) * ALPN, offering http/1.1 * successfully set certificate verify locations: * CAfile: /home/daniel/anaconda3/ssl/cacert.pem CApath: none * TLSv1.3 (OUT), TLS handshake, Client hello (1):That looks good. However, if I continue to wrap the connection into ssl, the handshake is done, but after that the error is given:
sslconn = ussl.wrap_socket(conn, server_side = True, keyfile = '/flash/cert/device.key', certfile = '/flash/cert/device.crt') Traceback (most recent call last): File "<stdin>", line 1, in <module> OSError: [Errno -1] ERR_MEMcurl continues:
* TLSv1.3 (IN), TLS handshake, Server hello (2): * TLSv1.2 (IN), TLS handshake, Certificate (11): * TLSv1.2 (IN), TLS handshake, Server key exchange (12): * TLSv1.2 (IN), TLS handshake, Server finished (14): * TLSv1.2 (OUT), TLS handshake, Client key exchange (16): * TLSv1.2 (OUT), TLS change cipher, Change cipher spec (1): * TLSv1.2 (OUT), TLS handshake, Finished (20): * TLSv1.2 (IN), TLS handshake, Finished (20): * SSL connection using TLSv1.2 / ECDHE-RSA-AES256-GCM-SHA384 * ALPN, server did not agree to a protocol * Server certificate: * subject: C=AU; ST=Some-State; O=Internet Widgits Pty Ltd; CN=192.168.4.1 * start date: Oct 10 12:24:08 2019 GMT * expire date: Dec 14 12:24:08 2038 GMT * issuer: C=AU; ST=Some-State; O=Internet Widgits Pty Ltd * SSL certificate verify result: unable to get local issuer certificate (20), continuing anyway. > GET / HTTP/1.1 > Host: 192.168.4.1 > User-Agent: curl/7.64.0 > Accept: */*Someone else seems to have no issues with this when he modified microWebSrv accordingly:
microWebSrv - HTTPS and WSS support #55
So it seems to be WiPy related.Here some additional info and input for easy reconstruction:
>>> os.uname() (sysname='WiPy', nodename='WiPy', release='1.20.1.r1', version='3138a13d on 2019-10-08', machine='WiPy with ESP32')device.crt:
-----BEGIN CERTIFICATE----- MIIDJzCCAg8CFC+R6gilkabtpc5uGukrYlG/J0hLMA0GCSqGSIb3DQEBCwUAMEUx CzAJBgNVBAYTAkFVMRMwEQYDVQQIDApTb21lLVN0YXRlMSEwHwYDVQQKDBhJbnRl cm5ldCBXaWRnaXRzIFB0eSBMdGQwHhcNMTkxMDEwMTIyNDA4WhcNMzgxMjE0MTIy NDA4WjBbMQswCQYDVQQGEwJBVTETMBEGA1UECAwKU29tZS1TdGF0ZTEhMB8GA1UE CgwYSW50ZXJuZXQgV2lkZ2l0cyBQdHkgTHRkMRQwEgYDVQQDDAsxOTIuMTY4LjQu MTCCASIwDQYJKoZIhvcNAQEBBQADggEPADCCAQoCggEBAMP/YDQnq1Jqrku782rY rV+UVun1STrjlt7bWb3cZn1ehzLcnjcP9VpIlVlNu6uTZhiJTKBDNXHrHzWpuYYX XWrel3/96sXZsFCVZqCegIG/4ZYunCzvJNDG3WSP5NjHHhI0z6600JCPeu8X3ha4 6OMzz13em+BYQ6AMstN7zYhovQmePZ6TZ7ZxLEeCsOwf5z2Enu02OceWjsDl+Db0 1lkSx6ExhhuG9YOHtP8l7GqpX/TVCoRNBv0lgUX+TuKfmbMbfsNvB2xW5e8KvJUp xPgBIDzz9V4ygrM1AeSeiqDeuNB0nnLceYUNGu5CLcRdv0He6PMIWc7gHEnRydI+ vBECAwEAATANBgkqhkiG9w0BAQsFAAOCAQEAHtoAWF9wsQ/S3qsbu6dRYDY4Ta3l ONlwigyDz2KCluLJ9mO6/ViIVu6PHWSSH63P6iDuENDw5rk5BG5SrQwfOlwH7agd cTOGJLMWtx2sUUe1YFMawSi8wlndp1tDZ3A7xISri5DACj3LQYC7mKUoiMNEyg0r FLxIrvKHDCXQOcvBgl99MfKQQgdbEmnlM8qmKRK9w4jEueySW4h0Iy4S0r4r8XbI K0v1WpezqnACw2KX3frPtiGyepSSQhIxk6FVewCw9jiAQwu0E6EBt9hmxJSrA8s3 wIWim08N218isZPbfRUy0lemhxybg+TQPx1maJ3FIh/aPRfoCSwLKIwwQw== -----END CERTIFICATE-----device.key:
-----BEGIN RSA PRIVATE KEY----- MIIEpgIBAAKCAQEAw/9gNCerUmquS7vzatitX5RW6fVJOuOW3ttZvdxmfV6HMtye Nw/1WkiVWU27q5NmGIlMoEM1cesfNam5hhddat6Xf/3qxdmwUJVmoJ6Agb/hli6c LO8k0MbdZI/k2MceEjTPrrTQkI967xfeFrjo4zPPXd6b4FhDoAyy03vNiGi9CZ49 npNntnEsR4Kw7B/nPYSe7TY5x5aOwOX4NvTWWRLHoTGGG4b1g4e0/yXsaqlf9NUK hE0G/SWBRf5O4p+Zsxt+w28HbFbl7wq8lSnE+AEgPPP1XjKCszUB5J6KoN640HSe ctx5hQ0a7kItxF2/Qd7o8whZzuAcSdHJ0j68EQIDAQABAoIBAQCuCYwRg9AbJOOU GFbzX2fD4WKz6LyX8BO93CT59EWFuXRv83sCBcel3aHQZLfqiL41t2U1QbipaVCT RBybNxAan4EDhCL+gGiRhbhVk6kkjY/w3X6MX+XfBVb9vtBEtbq8C+0Gg0RXuTA+ MoFgx9z0MsNF5S+grH+QFPaN1/cP0fL+dMe944pzUT+51oJy8R+47+vA0h1Hr7kW JSrCcqLBQ3X5sV+RGTX4pgKkMZWcqopXuigD7nFOAynq6rJWRuwzW6xEHykPOVch 58mgAKYTKH7FPVErQbidWL/0DLEWbAh1GJl+iXP5f9buCPbGVkKf7A/IElYRSnDg HX7hWiipAoGBAOwXdEcXWMg7OHKXoKdyNlttavPZV77XPwDaQIDLL8xybDab+32A reSmyY5GdQ672wJY8qqmJghIn3DaQO+732MA1p4C1iMucLoF258n/p3MH6ZtF9xp vqtUS5TGVfuYG2uwdG7tGedGgq4hmBCiCMw1xdrBtc6Hh6SQCQMcHwFTAoGBANSG Z7Lk07NchHAM7CUUFZP38JzvisProW3VDsbF9BX/tzUH0XTR9MZ9+BcalASETTIK DXgP9OkPSI54wiA/wios47i2e1wY77CHYTI1Z5ZUA/TEcrqcFrRd8mLG5bTYBCPL iuURRu2ybA1HRq6ooZO+q8rcGlvAsAI0zqqmfmyLAoGBALMqjXSR9C9oOctE5IeO dk/l9n991kgew1JbTw4upGSMBTFgKHey2sSmClmtgJIg3/ClHeuBUWWB73XOO+9y 7PEOJtEdJ/LlAGk7ntLmoCSSTwaWzb/Yg/kzbHRIG+JmKZENBR9VUg4ghXWuSt98 iB6pRDBiRx2n3rl1EVHJ2oG/AoGBAJayg3+noLHTTZnCoAQevLpCmpw9gzEvuTUP Wb37Cfw7aiaxV4W1hxLkqfGACCs3wSFVXX2gGvLTwog7+rMxYrXTRNpqkwiYKgYL yRD4K26+PlvmnM/T9ImLAF+oV6OndTAImYGagaf014eG3gjlTEVec6SR9CLRfDzk QxNgoc7HAoGBANv9gV8Taq1f9U8I1svI7ITYuB+zLU4A9r/vnHmSP/s0mAYVeu+C S/e1ErBRe5TNmp3ME1J4PmY9cww0KrLWmLFRHQI97jskN+bxTNE4Em/JcQ3EZAZg ZvXBYQ7kPQD3poBlXZ/DXERWnrDTuK7ZXdOOab0JlF/kiwJSi3hzrnMG -----END RSA PRIVATE KEY-----
