    urequests
    1 Posts 1 Posters 226 Views 1 Watching
    • K Offline
      kjm
      urequests takes 20-30s to throw an OSError if it doesn't get a response. We can't figure out where this timeout comes from. There is no timeout in the original requests library
      def request(method, url, data=None, json=None, headers={}, stream=None):
          try:
              proto, dummy, host, path = url.split("/", 3)
          except ValueError:
              proto, dummy, host = url.split("/", 2)
              path = ""
          if proto == "http:":
              port = 80
          elif proto == "https:":
              import ussl
              port = 443
              raise ValueError("Unsupported protocol: " + proto)
          if ":" in host:
              host, port = host.split(":", 1)
              port = int(port)
          ai = usocket.getaddrinfo(host, port)
          ai = ai[0]
          s = usocket.socket(ai[0], ai[1], ai[2])
      We thought we'd try to add a shorter timeout following https://docs.python.org/3/library/socket.html#socket.getaddrinfo
      def request(method, url, data=None, json=None, headers={}, stream=None, timeout=5):
          try:
          except ValueError:
              path = ""
              port = 80
              import ussl
              port = 443
          if ":" in host:
              port = int(port)
              s = usocket.socket(2,1,0)
          if timeout is not None:
              assert hasattr(usocket.socket, 'settimeout'), 'Socket does not support timeout'
              s.settimeout(timeout)
          ai = ai[0]
      but it's not giving the 5s timeout we'd like. Can anyone see a way forward with this?
