    NB-IoT to AWS?
    3 Posts 3 Posters 322 Views 3 Watching
    • R Offline
      riverj17
      Hey everyone, I'm working on a project that consists of having a gas sensor connected to the FiPy board which is connected to T-Mobile using NB-IoT. I want to have the collected data from the sensor transmit to Amazon Web Services (AWS).
      From AWS I have the AWS_ROOT_CA, AWS_CLIENT_CERT, & AWS_PRIVATE_KEY downloaded onto my mac computer. The documentation says to place these files in a /flash/cert folder.
      How do I perform this function if I'm using NB-IoT since the documentation uses WIFI?
      Shown below is the config.py file
      AWS general configuration
      AWS_PORT = 8883
      AWS_HOST = 'ABCDEFGHIJK.iot.us-west-2.amazonaws.com'
      AWS_ROOT_CA = '/flash/cert/aws_root.ca'
      AWS_CLIENT_CERT = '/flash/cert/aws_client.cert'
      AWS_PRIVATE_KEY = '/flash/cert/aws_private.key'
      ################## Subscribe / Publish client #################
      CLIENT_ID = 'PycomPublishClient'
      TOPIC = 'PublishTopic'
      OFFLINE_QUEUE_SIZE = -1
      DRAINING_FREQ = 2
      CONN_DISCONN_TIMEOUT = 10
      MQTT_OPER_TIMEOUT = 5
      #LAST_WILL_TOPIC = 'PublishTopic'
      #LAST_WILL_MSG = 'To All: Last will message'
      ####################### Shadow updater ########################
      #THING_NAME = "my thing name"
      #CLIENT_ID = "ShadowUpdater"
      #CONN_DISCONN_TIMEOUT = 10
      #MQTT_OPER_TIMEOUT = 5
      ####################### Delta Listener ########################
      #CLIENT_ID = "DeltaListener"
      ####################### Shadow Echo ########################
      THING_NAME = "Smart_Meter"
      CLIENT_ID = "ShadowEcho"
        jirkakrepl
        Hi @riverj17,
        I moved your topic to the correct section.
        software developer @ Pycom
        • V Offline
          VInay Parekh
          Hi @riverj17,
          Can you please share the new topic, where you moved?
