    Test DNS NB-IoT FiPy (v. 41019)
    10 Posts 4 Posters 597 Views 5 Watching
      Tgasser
      I'm looking for help for this mistake:
      Do you have any ideas please?
      Thank you in advance!
      O 1 Reply Last reply Reply Quote 0
        Tgasser
        No one ?
        I have another mistake when I try this way:
        But I can't find any information to unlock the problem either.
          robert-hh @Tgasser
          @Tgasser This sequence works for me:
              s = socket.socket()
              ss = ssl.wrap_socket(s)
              socket.dnsserver(0, "8.8.8.8")
              i = socket.getaddrinfo('www.google.com', 443)[0][-1]
              # i = ('172.217.22.110', 443)
              print('Connecting to socket...')
              ss.connect(i)
              print('Send...')
              ss.send(b"GET / HTTP/1.0\r\n\r\n")
              print(ss.recv(4096))
              print('Close...')
              ss.close()
          • O Offline
            oligauc @Tgasser
            @Tgasser Please can you use secure sockets ? Most servers no long accept connections on port 80.
            s = socket.socket()
            s.connect(socket.getaddrinfo('www.google.com', 443)[0][-1])
            print(s.recv(4096))
            s.close()
              Tgasser @oligauc
              @oligauc @robert-hh I tried with your code I get the same errors as before. If I use getaddrinfo then it returns EAI_FAIL and if I put the IP address directly with the port then it returns ECONNABORTED :/
                Tgasser @robert-hh
                @robert-hh @oligauc I'm only starting on networks and IoT and I was wondering if you didn't know about tests maybe more basic to try to see where the problem might come from?
                  Tgasser
                  Even with the last update of the pycom firmware I couldn't find a solution...
                    Tgasser
                    Maybe some progress? I have no error this time when I do ss.connect() but nevertheless it remains blocked at this step for more than an hour... Any idea, please?
                      Tgasser
                      Hello !
                      I still have an error that is EHOSTUNREACH yet google servers should be available? I use the Windows console with tracert google.com to know the IP address then I enter it in the socket.connect to avoid the EAI_FAIL bug of the getaddrinfo()...
                      If you have any ideas I'm listening, thank you :)
                      • V Offline
                        v2h
