FiPy + Expansion Board 3.1 - Analog input calibration
So I wrote the code looking at the examples. My analog output from the sensor connected to P18 of the Expansion Board 3.1 (I did upgraded its firmware before that).
history = array.array('I') adc = ADC(bits=12) print("adc: {}".format(adc)) # CALIBRATION # Output Vref of P22 adc.vref_to_pin('P22') print("set vref to pin 22") adc.vref(1310)#1100) print("set adc ref value to 1310") # ADC.ATTN_11DB — the full range voltage: 3.3V adc_c = adc.channel(pin='P18', attn=ADC.ATTN_11DB) print("got adc channel on P18") while True: v = adc_c.voltage() history.append(v) print("Voltage: {}".format(v))So when I plug FiPy and measure P22 of the Expansion Board 3.1 I get values 1310 on average...When I run this with device connected I get values like that while sensor is not measuring anything (but this is ECG sensor so is it that noisy/sensitive?)
At any rate I do not understand all these values and have no idea if they are correct. I am also confused about calibration despite reading all available posts on this forum. Is P22 has 1.1V by default? What else do I need to do besides what I did in my code... I really do not care in what units the results are displayed - I just need them to be accurate relatively to each other so I can get accurate EKG graph...
Voltage: 2270 Voltage: 2174 Voltage: 1601 Voltage: 1118 Voltage: 1115 Voltage: 1484 Voltage: 2094 Voltage: 2302 Voltage: 2044 Voltage: 1436 Voltage: 1065 Voltage: 1175 Voltage: 1636 Voltage: 2188 Voltage: 2261 Voltage: 1930 Voltage: 1320 Voltage: 1052Also just want to verify that I used voltmeter correctly - touch the ground pin on Expansion Board with black wire from voltmeter and P22 on Expansion Board with red wire from voltmeter. I could not touch the pin directly - the holes on Expansion Board are too small (ok, don't lough), so I used extra wires and sometimes headers to touch them and was getting most of the time reading of 315 mV (using wires). And then with a header and pins got 1310 mV...
Any ideas?
