Conversion code from pyboard
I use the following code on my pyboard:import array
import pyb
import utime
import timetime.sleep(2)
adc1=pyb.ADC(pyb.Pin.board.Y12)
buf1=array.array('H',bytearray(40000))
tim=pyb.Timer(6, freq=2000)
adc1.read_timed(buf1,tim)with open('chanel1.dash','w') as f:
for val in buf1:
s1 = str(val)
f.write(s1+'\n')And I want to adapt it and apply it on my wipy.
I wrote this:import array
import os
from machine import SD
sd=SD()
os.mount(sd,'/sd')time.sleep(2)
from machine import ADC
adc=ADC()
adc1=adc.channel(pin='P13')buf1=array.array('H',bytearray(5000))
from machine import Timer
tim=Timer(6, mode=Timer.PERIODIC, width=32)
tim.channel(Timer.A, freq=1000, polarity=Timer.POSITIVE)
adc1.read_timed(buf1,tim)with open('/sd/chanel1.dash','w') as f:
for val in buf1:
s1 = str(val)
f.write(s1+'\n')But it's not working... it tells me "cannot create Timer instance"(line 15)
One of you may be know how to solve this ?
And someone know what is the limit size that I can put for the buffer ? It seems like there is some problem of allocation as well.
Also, I think that the 'read_timed' command doesn't exist for the Wipy..or at least I havn't seen it in the documentationThank you
look here
https://docs.pycom.io/pycom_esp32/library/machine.Timer.html
https://docs.pycom.io/pycom_esp32/pycom_esp32/tutorial/includes/timers.htmlno
read_timeddoes not exist please add this in
https://forum.pycom.io/topic/433/features-wish-list
