    OSError: in error.log file
    wipylopy
    6 Posts 3 Posters 323 Views 3 Watching
    • W Offline
      Wolli01
      I have created an error.log file to find errors.
      Enclosed is an excerpt of the file and below that the Main-File line.
      Who can help more and tell what these error messages mean and how I can avoid them?
      25.12.2019;05:10:21
      File "main.py", line 790, in <module>
      File "/flash/lib/urequests.py", line 116, in post
      return request("POST", url, **kw)
      File "/flash/lib/urequests.py", line 102, in request
      raise
      File "/flash/lib/urequests.py", line 60, in request
      s.connect(ai[-1])
      OSError: [Errno 113] EHOSTUNREACH
      Main Zeile:
      res = urequests.post(url, data=json.dumps(userdata))
      25.12.2019;05:21:30
      File "main.py", line 270, in <module>
      File "/flash/lib/urequests.py", line 113, in get
      return request("GET", url, **kw)
      raise
      File "/flash/lib/urequests.py", line 62, in request
      s = ussl.wrap_socket(s, server_hostname=host)
      OSError: [Errno -26624] MBEDTLS_ERR_SSL_TIMEOUT
      Main Zeile:
      res = urequests.get(settings.Gateway+'onlinesettings.txt')
      25.12.2019;05:44:25
      File "main.py", line 296, in <module>
      Main Zeile:
      res3 = urequests.get(settings.Gateway+'onoff.txt')
      25.12.2019;05:47:11
      raise
      Main Zeile:
      S J 2 Replies Last reply Reply Quote 0
        svonbentzel @Wolli01
        @Wolli01
        Hello, can you share your code to generate this log file? I try it a few times and don’t get it :-(
        Please 🥺
        W 1 Reply Last reply Reply Quote 0
        • W Offline
          Wolli01 @svonbentzel
          @svonbentzel
          Yes, please.
          try: # Ab hier beginnt die Fehlerüberwachung
          #Code........................
          # Fehler abfangen und in die error.log speichern------------------------------
          except Exception as e:
              # Fehler Lampe in Rot anzeigen!
              pycom.rgbled(0xFF0000) #Rot
              print("Fehlermeldung")
              print(e)
              # Fehlerdatei erstellen
              import sys
              with open ('/sd/error.log', 'a') as f:
              #Fehlerbeschreibung--------------------
                  f.write(str(LogDateTime) + "\n")
                  sys.print_exception(e, f)
                  f.write("\n")
              time.sleep(10)
              machine.reset() # Neustarten
              #machine.deepsleep (1000)
            svonbentzel
            Awesome ! Many thanks 😊
              jcaron @Wolli01
              @Wolli01 I believe the errors are self-explanatory.
              • The first one is “host unreachable”, which points to a network issue
              • The other one are timeouts during the TLS negotiation. That’s again most likely a network issue.
              Wireless communication is subject to all kinds of issues which makes it not 100% reliable, this is to be expected and managed. When an error occurs, you should retry, either right away (usually with a slight pause which increases each time, a random offset, and a limit to the number of retried), or through some queuing mechanism. The details depend a lot on how important the data is, what kind of delay you can accept, the frequency and size of the transmissions, your dependence on battery, and so on.
              • W Offline
                Wolli01 @jcaron
                @jcaron Many thanks for your info
