    How to get FiPy working on KPN LTE-M network?
    3 Posts 2 Posters 163 Views 2 Watching
      avbalen
      Could someone please post a working example of how to get a FiPy operational on the KPN LTE-M network in the Netherlands? There are some scattered messages in these forums and in the KPN forums, some people seem to have it working but a complete, always working, example is nowhere to be found. Too bad as FiPy is around for quite some time now (as is the KPN LTE-M network). Information over what should be an entirely trivial operation appears to be non-existent.
      For that matter, please use the latest firmware and modem firmware (41065 at time of writing).
      Thanks in advance!
      • H Offline
        han
        Hi avbalen,
        I am also struggling with connecting my FiPy to the kpn network but I make some progress.
        The firmware i use is 1.20.rc13 with the pycom firmware updater version 1.16.1.
        The version of the Pymakr plugin is 1.5.6.
        import ssl
        from network import LTE
        # Colors
        off = 0x000000
        red = 0xff0000
        green = 0x00ff00
        blue = 0x0000ff
        yellow = 0xffff00
        # Turn off hearbeat LED
        lte = LTE()
        #set the apn
        lte.send_at_cmd('AT+CGDCONT=1,"IP","ltem.webtrial.m2m"')
        lte.send_at_cmd('AT+CFUN=0') # disable modem
        lte.send_at_cmd('AT!="clearscanconfig"') # clear scanned frequencies
        lte.send_at_cmd('AT!="addscanfreq band=20 dl-earfcn=6400"') # set scanned frequency
        lte.send_at_cmd('AT+CFUN=1') # enable modem
        lte.attach()
        # wait for the attach flag to set and use the connect call
        # the modem will auto connect from the previous call regardless but still need to call this otherwise the unit does not know it's connected
        while not lte.isattached():
            pycom.rgbled(red)
            time.sleep(0.25)
            pycom.rgbled(off)
            print("not attached")
        lte.connect()
        while not lte.isconnected():
            pycom.rgbled(yellow)
            time.sleep(0.25)
            pycom.rgbled(off)
            print("not connected")
        pycom.rgbled(blue)
        s = socket.socket()
        s = ssl.wrap_socket(s)
        s.connect(socket.getaddrinfo('www.google.com', 443)[0][-1])
        s.send(b"GET / HTTP/1.0\r\n\r\n")
        print(s.recv(4096))
        s.close()
        pycom.rgbled(green)
        With the above printed code the FiPy attached to the KPN Nenetwork. I can see that in the Jasper Wireless portal.
        The green dot shows that the sim is in use.
        But by the part that the FiPy should connect to the network I got stuck
        The rgb led flash one time red and the serial terminal keeps printing "not connected".
        Maybe you know a trick to get further with the code so it will work well.
        • H Offline
          han @han
          @avbalen
          It works when you update your sqn3330 to version CATM1 41056.
