Gpy bricked after adding Pybytes firmware
Finally got LTE up and running, thought I'd test out Pybytes, and now I've got bigger problems.
After following the steps here: https://docs.pycom.io/pybytes/connect/quick/ I'm now completely unable to communicate with my Gpy. In Atom, all I see is "Connecting to COM3..." with no way to access REPL. If I try to upload anything, I get "Upload failed: timeout. Please reboot your device manually." If I hit Ctrl+C, nothing happens.
I've attempted safe boot and firmware reset, with no luck. Any suggestions? Sure is a finicky little thing.
Fixed this by using the erase all feature from: https://docs.pycom.io/advance/cli/
A little heavy handed but the board seems to be back to normal. I'm pretty afraid to touch pybytes again though. Time to look into alternative for uploading data.
