    write bluetooth FiPy
    4 Posts 2 Posters 173 Views 2 Watching
      Tgasser
      I don't understand why, but when I do char.write(), nothing happens... It print well 'ok' then I can wait nothing happens... Thanks if you have an idea !
      from network import Bluetooth
      import ubinascii
      bt = Bluetooth()
      bt.start_scan(-1)
          adv = bt.get_adv()
          if adv:
              print(ubinascii.hexlify(adv.mac))
              if bt.resolve_adv_data(adv.data, Bluetooth.ADV_NAME_CMPL) == 'Blabla':
                try:
                    conn = bt.connect(adv.mac)
                    services = conn.services()
                    for service in services:
                        time.sleep(0.050)
                        if service.uuid() == XXX
                            print('Reading chars from service = %x' % service.uuid())
                            chars = service.characteristics()
                            for char in chars:
                                    if (char.uuid()==XXX):
                                        if(char.properties() & Bluetooth.PROP_WRITE):
                                            print('ok')
                                            char.write(b'0xa01f')
                    conn.disconnect()
                    break
                except:
                    pass
              time.sleep(0.050)
        jcaron @Tgasser
        @Tgasser You have the code-quoting quotes the wrong way around, it's ```
        I don't think you are sending what you think or want: you are sending the characters 0, x, a, 0, 1, f, not 0xa0 and 0x1f.
        Instead of b'0xa01f', you can write b'\xa0\x1f' or bytes([0xa0,0x1f].
        Note that the order may be reversed based on the required endianness.
        T 2 Replies Last reply Reply Quote 1
          Tgasser @jcaron
          @jcaron Thank you for your help, it works the way I wanted it to! Thanks for your advice.
            Tgasser @jcaron
            @jcaron I read several articles to invert the bytes and read the right values. If I have val= b'\xdd\xee' tanks to struct.pack('<h', *struct.unpack('>h', val)) I get the inverse val= b'\xee\xdd'.
            However, for val= b'\xxaa\xbb\xcc\xdd' I can't find a way to get val=b'\xdd\xcc\xbb\xaa'.
            Do you have any idea how to help me? Thank you in advance!
