    Cannot Update FW On New FiPy in Pysense
    5 Posts 2 Posters 211 Views 2 Watching
    • K Offline
      kurtsmith38
      New Pycom user here. I just received a FiPy and a Pysense board. I was able to update the firmware of the Pysense board, but so far I have been unable to update the FiPy's firmware. When attempting the update, I receive the message "Could not connect to the board." I'm using the firmware updater utility (ver 1.16.1) on Win10.
      I'm able to successfully run commands via REPL in Atom, so I know that my PC is able to communicate with the board (yes, I am closing Atom before resetting the FiPy and attempting the upgrade). However, I've noticed some commands entered via REPL produce a guru meditation error (e.g. if I attempt to import the time lib AFTER importing the pycom lib). Hopefully I'm just doing something wrong and these aren't signs of a damaged board.
      Thank you for any advice you can provide.
      -Kurt
      • K Offline
        kurtsmith38
        I tried a different Win10 computer with a fresh install of the firmware updater utility, but same result. Do I have to have an Expansion Board 3.0+ to perform a firmware update on the FiPy?
        Can anyone assist? Is there a different section I should post this type of issue under?
        Thank you,
        Kurt
        • E Offline
          Edward Dimmack
          I have the same problem. I was able to upgrade the firmware from a file though.
          So if you download the version you want from here,
          https://software.pycom.io/downloads/FiPy.html
          Then select "Flash from local file" that worked for me.
          • K Offline
            kurtsmith38 @Edward Dimmack
            @Edward-Dimmack That worked for me as well, thank you for the suggestion. However, I don't see the latest firmware posted here. Is there another location that has the latest 1.20.1.x firmware?
            • K Offline
              kurtsmith38 @kurtsmith38
              Flashing in offline mode (i.e. using a local file) seems to work for me. For anyone with the same issue, I found the latest FiPy Pybytes firmware via:
              https://software.pycom.io/downloads/pybytes/FiPy.html
              Legacy builds are at https://software.pycom.io/downloads/FiPy.html as shown by @Edward-Dimmack.
