NTP sync FiPy
I have a problem with the Fipy I would like to sync the rtc with ntp_sync but I never get the case synced.
If you have any idea to share... Thanks.
I made it work with the following:
rtc = machine.RTC() rtc.ntp_sync("pool.ntp.org", update_period=15) time.sleep(5) print(rtc.now())The update period, if not given as an argument, is kinda slow. As i use in the example, minimum update period is 15 sec, so you may want to sync with the server in boot.py, and do some other stuff / wait a bit in your main.py, before you print the rtc time.
