Fipy connect on Putty but can't connect on Atom+pymakr.....Windows 7
The Fipy board is connected via the serial USB (as mentioned on the manual) and i can communicate with it using putty, however there's no Fipy Wifi Network (that's suppose to be activated as a default mode ) and Atom can't see the board . Kindly any suggestion , i spent a lot of time trying fix this issue.
Installing python 2.7 instead of 3.X solves the problem , now the serial port is working fine .
The Problem was Solved, in the firmware updater program instead of choosing
Type : Pybytes ----> Cause the Problem on the Fipy (i Don't know why)
instead i choosed ---> Type: Pybytes -legacy (and it's work well now)
But due to Driver issue (for Windows 7) i still can't communicate with the board through the USB-Serial (Only by WiFi )
