FiPy + Pytrack + Lipo Battery Issues
I am trying to use a FiPy with a Pytrack board to run a program. When I am running the program on the board while connected to a lipo battery everything runs fine. How ever when I then plug in a micro usb to charge the battery the program stops running and the board appears to enter a sleep state. The power has to be connected and reconnected in order for the program to restart.
The same thing happens if I start the program with both the charger and battery connected. The program runs fine until I disconnect the charger and attempt to run just off battery. Again the program stops running
How can I get it so that the program never stop running when the power source it switched?
The end goal is to be able to put it into a "low power mode" when charging. I already have it detecting when it is on the charger but cannot get the program to keep running.
