    LoPy4 - TTN Lora - Uplink OK - Downlink not working
    3 Posts 2 Posters 276 Views 2 Watching
    • X Offline
      xavier
      Hi from Australia,
      Project --> IoT with LoRaWAN, Pycom, The Things Network & Node-RED
      https://core-electronics.com.au/tutorials/iot-with-lorawan-pycom-the-things-network-and-node-red.html
      Lorawan gateway at home --> Sentrius Gateway
      Device --> LoPy4 + PyTrack
      Firmware version --> 1.20.2.rc3
      I searched on different forum on the different ways to join in OTAA mode in adding the Australian channels and most of the configurations were working.
      Basically I can join the gateway
      I can send data from the LoPy, it is received by the Application and I can received it in Node-RED.
      So far, so good.
      Data received from the LoPy - Application Traffic
      The LoPy is sending "water_level: 0"
      and in response, Node-RED is transmitting --> "pump_running: 1"
      Data received from the LoPy - Gateway Traffic
      The Application receives the data sent by Node-RED but the LoPy doesn't received it from the gateway.
      I tried different ports but no luck.
      The Node-RED code is pretty simple:
      I don't know if this is a problem with how I join the network? (Channels created, ...)
      or maybe the is something in the LoPy code that is not correct
      Would anyone have an idea of what am I doing wrong?
      Could it be that the JSON sent from node-RED is not correct?
      See --> link
      I looked there without any luck:
      --> link
      --> link
      --> link
      --> link
      --> link
      Could this be that
      Thank you for your help.
      Xavier
      CODE LOPY4
      from network import LoRa
      import struct
      import binascii
      import utime
      LORA_FREQUENCY = 916800000
      LORA_GW_DR = "SF7BW125" # DR_5
      LORA_NODE_DR = 5
      COLOUR_WHITE = 0xFFFFFF
      COLOUR_BLACK = 0x000000
      COLOUR_RED   = 0xFF0000
      COLOUR_GREEN = 0x00FF00
      COLOUR_BLUE  = 0x0000FF
      pycom.rgbled(COLOUR_BLACK)
      print("****** Farmer App OTAA *******")
      # lora config
      lora = LoRa(mode=LoRa.LORAWAN, region=LoRa.AU915)
      # access info from ttn console (note; we just need the app id & app key)
      dev_eui = binascii.unhexlify('WWWWWWWWWWWW') # these settings can be found from TTN
      app_eui = binascii.unhexlify('ZZZZZZZZZZZZZZZZZ')
      app_key = binascii.unhexlify('XXXXXXXXXXXXXXXXXXXXXXXXXXXX')
      for i in range(0, 72):
          lora.remove_channel(i)
      # adding the Australian channels
      print("add channels")
      for i in range(8, 16):
          lora.add_channel(i, frequency=915200000 + i * 200000, dr_min=0, dr_max=3)
          lora.add_channel(65, frequency=917500000, dr_min=4, dr_max=4)
      for i in range(0, 8):
          lora.add_channel(i, frequency=923300000 + i * 600000, dr_min=0, dr_max=3)
      # attempt join - continues attempts background every 15 seconds
      lora.join(activation=LoRa.OTAA, auth=(dev_eui, app_eui, app_key), timeout=0)
      # wait for a connection to be established
      print('Waiting for LoRaWAN network connection...')
      while not lora.has_joined():
          utime.sleep(1)
          if utime.time() > 15:
              print("possible timeout or collision")
              machine.reset()
          pass
      print('Network joined!')
      s.setsockopt(socket.SOL_LORA, socket.SO_DR, LORA_NODE_DR)
      s.setblocking(False)
      pump_running = False
      water_level = 0
      empty_level = 0
      full_level = 5
      def check_downlink_messages():
          global pump_running # We need to tell Python to use the variable
                              # defined outside this function
          downlink_message, port = s.recvfrom(256) # See if a downlink message arrived
          #print(downlink_message)
          #print(port)
          if not downlink_message: # If there was no message, get out now
              return
          print("Downlink message received!")
          if downlink_message[0]: # The first byte is non-zero
              print("Starting the pump")
              pump_running = True
              print("Stopping the pump")
      def send_level():
          print('Sending water level: {}'.format(water_level))
          uplink_message = bytes([water_level])
          s.send(uplink_message)
      def adjust_water_level():
          global water_level  # We need to tell Python to use the variable
          if pump_running:
              if water_level < full_level:    # Can't be overfilled
                  water_level += 1            # Water level rises
              if water_level > empty_level:   # Can't be less than empty
                  water_level -= 1            # Water level drops
      while(True):
          # Code at the indent happens every 10 seconds
          send_level()
          for i in range (10):        # 10 x 1 second delay
              # Code at this indent happens every second
              if pump_running:    # At any time the pump might be stopped
                  pycom.rgbled(COLOUR_GREEN)
                  pycom.rgbled(COLOUR_RED)
              time.sleep(1)           # 1 second delay
      • X Offline
        xavier @xavier
        @xavier
        Problem solved, I didn't have the Encoder setup properly:
        function Encoder(object, port) {
          var bytes = [];
          if (object.pump_running === 0 || object.pump_running === 1) {
            bytes[0] = object.pump_running ? 1 : 0;
          // There is no separate converter and validator function for this direction. Return an empty array to drop the message.
          // https://www.thethingsnetwork.org/docs/devices/uno/quick-start.html
          return bytes;
        • B Offline
          barryjump
          @xavier where are you running that encoder? I'm trying to do something similar with node-red.
