Atom difficulties
Having problems with Atom & my GPYs again. Only thing I can think of as a possible cause was a recent obligatory Windows10 update?
- After I run a program from Atom I have to Disconnect then reconnect the Pymakr package. If I don't attempting to run a program produces output like this
>>> Running C:\Users\Kris\Google Drive\My Documents\Pycom\main\flash\boot.py >>> >>> �ets Jun 8 2016 00:22:57 rst:0x7 (TG0WDT_SYS_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) configsip: 0, SPIWP:0xee clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:DIO, clock div:1 load:0x3fff8020,len:8 load:0x3fff8028,len:2136 load:0x4009fa00,len:19944 entry 0x400a05e8 Pycom MicroPython 1.20.1.r1 [15b6d69] on 2019-11-02; GPy with ESP32 Type "help()" for more information. >>> red); return 0,0,0 # multi returns can't have Nones Traceback (most recent call last): File "<stdin>", line 1 SyntaxError: invalid syntax >>> >>> sah=_nvs_get('sah') # sah sample and hold Traceback (most recent call last): File "<stdin>", line 1, in <module> NameError: name '_nvs_get' isn't defined >>> print(); print(' pressure probe off'); probepwr=Pin('P8', Pin.OPEN_DRAIN); probepwr.value(1) # probe OFFd at each powerup in case _pwrup_reason does deepsleep pressure probe off Traceback (most recent call last): File "<stdin>", line 1, in <module> NameError: name 'Pin' isn't defined >>> def _getdepth(): ... try: ... global sah ... print (' pressure probe on', end=2L for a 2m dia tank ... if dt>4*3600: NetFlow=0 # dot every 4 hr, 20mm/4h=5mm/h (~16L/h) min detectable flow ... if d>dh>19 and t2>t1>999999: print(' store', t2, h2); NetFlow=int(3600*dv/dt); pycom.nvs_set('epoch', t2); pycom.nvs_set('depth', h2) # depth>depth>difference, valid epochs ... res='t' if d>dh>19 else 'f'; print('', d, h2-h1, res, end=' '); res='t' if t2>t1>999 else 'f'; print(t2, t1, res) ... if dh>sah and cycle>2: sah=dh; pycom.nvs_set('sah', dh); msg=' level change '+str(h2-h1); print(msg); _mkpyld(0, msg)- Since Disconnecting from the GPY then convincing the Pymakr plugin to work generally takes several attempts I thought it might be quicker to upload programs rather than try to run then from Atom. In this case I get
Uploading project (flash)... Not safe booting, disabled in settings Reading file status Failed to read project status, uploading all files Creating dir lib [1/2] Writing file boot.py (73kb) Failed to write file, trying again... Failed to write file, trying again... Failed to write file: name 'f' isn't defined >>> [2/2] Writing file lib/onewire.py (8kb) Failed to write file, trying again... Failed to write file, trying again... Upload failed: Failed to write file: invalid sy. Please reboot your device manually. import machine >>> machine.reset() ets Jun 8 2016 00:22:57Having to make several attempts to reload Pymakr after each code improvement is misery, it's like swimming through molasses! Does anyone have any suggestions? I'm running pymakr 1.4.16 on Atom 1.40.1
I am having the same issue and error messages with Fipy and Gpy.
OKets Jun 8 2016 00:22:57rst:0x7 (TG0WDT_SYS_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
load:0x3fff9028,len:8
load:0x3fff9030,len:1060
load:0x4009fa00,len:0
ho 12 tail 0 room 4
load:0x4009fa00,len:14084
entry 0x400a05d4
Start program? (y/n)
